Rival CM4015 Water Tubes Replacement
    1. Rival CM4015 Water Tubes Replacement, Base Plate: step 1, image 1 of 2 Rival CM4015 Water Tubes Replacement, Base Plate: step 1, image 2 of 2
      • Remove the three 16 mm tri-point screws from the base plate.
      Ask FixBot
    2. Rival CM4015 Water Tubes Replacement: step 2, image 1 of 2 Rival CM4015 Water Tubes Replacement: step 2, image 2 of 2
      • Remove the base plate by pressing the plastic body away from the metal plate with your thumbs.
      Ask FixBot
    1. Rival CM4015 Water Tubes Replacement, Power Button: step 3, image 1 of 1
      • Remove the 8mm Phillips screw that attaches the power button to the inside of the coffee maker.
      Ask FixBot
    2. Rival CM4015 Water Tubes Replacement: step 4, image 1 of 2 Rival CM4015 Water Tubes Replacement: step 4, image 2 of 2
      • Use a flat head screwdriver to pry the power button from its slot in the body of the device.
      • Make sure the tool is pressed securely under the plastic clip, in order to not break it.
      Ask FixBot
    3. Rival CM4015 Water Tubes Replacement: step 5, image 1 of 2 Rival CM4015 Water Tubes Replacement: step 5, image 2 of 2
      • Clean both the button and its slot before replacing the power button.
      Ask FixBot
    1. Rival CM4015 Water Tubes Replacement, Heating Element: step 6, image 1 of 1
      • Remove the two 8 mm Phillips screws from the plastic body.
      Ask FixBot
    2. Rival CM4015 Water Tubes Replacement: step 7, image 1 of 2 Rival CM4015 Water Tubes Replacement: step 7, image 2 of 2
      • Remove the two 8 mm Phillips screws from the chassis of coffee maker.
      • Pull back the metal backing from the plastic body.
      Ask FixBot
    3. Rival CM4015 Water Tubes Replacement: step 8, image 1 of 3 Rival CM4015 Water Tubes Replacement: step 8, image 2 of 3 Rival CM4015 Water Tubes Replacement: step 8, image 3 of 3
      • Remove the four 8 mm Phillips screws from the inner plastic body.
      • You will need a long, thin Phillips screw driver to get this deep into the device.
      Ask FixBot
    4. Rival CM4015 Water Tubes Replacement: step 9, image 1 of 2 Rival CM4015 Water Tubes Replacement: step 9, image 2 of 2
      • Flip the device upside down and remove the outer plastic body from the device by pulling straight up.
      • Take your time to make sure the thin cables within the device don't tear.
      Ask FixBot
    5. Rival CM4015 Water Tubes Replacement: step 10, image 1 of 1
      • Remove the two 8 mm Phillips screws from the metal backing.
      Ask FixBot
    6. Rival CM4015 Water Tubes Replacement: step 11, image 1 of 1
      • Remove the 4 springs holding the water tubes by squeezing the 2 prongs together.
      • You may also use pliers for this step if the springs are too strong.
      Ask FixBot
    7. Rival CM4015 Water Tubes Replacement: step 12, image 1 of 1
      • Bend the heating element back and forth to wiggle the water tubes loose from the plastic.
      Ask FixBot
    1. Rival CM4015 Water Tubes Replacement, Water Tubes: step 13, image 1 of 1
      • Remove the two rubber water tubes from the heating element by firmly pulling each at a 90 degree angle from the socket.
      Ask FixBot
Michael Murdock
279 Reputation
2 Guides authored
Cal Poly, Team 10-6, Livingston Fall 2016 Member of Cal Poly, Team 10-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G6
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 515
