Up to 20% off select tools
Rival CM4015 Power Cable Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
90
All Time:
699
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Before beginning, double check that you have disconnected the power cable from the outlet. You will be taking out the base plate and replacing the power cable. You will need to cut the power cable and solder on the new one.
    1. Rival CM4015 Power Cable Replacement, Base Plate: step 1, image 1 of 2 Rival CM4015 Power Cable Replacement, Base Plate: step 1, image 2 of 2
      • Remove the three 16 mm tri-point screws from the base plate.
      Ask FixBot
    2. Rival CM4015 Power Cable Replacement: step 2, image 1 of 2 Rival CM4015 Power Cable Replacement: step 2, image 2 of 2
      • Remove the base plate by pressing the plastic body away from the metal plate with your thumbs.
      Ask FixBot
    1. Rival CM4015 Power Cable Replacement, Power Cable: step 3, image 1 of 1
      • Remove the two 8mm Phillips screws from the plastic body.
      Ask FixBot
    2. Rival CM4015 Power Cable Replacement: step 4, image 1 of 1
      • Pull the cord and cut the black and red wires across the black heat shrink.
      • Be careful when soldering the new power cable.
      Ask FixBot
Author
with
Luis Villalpando
113 Reputation
1 Guide authored
Cal Poly, Team 10-6, Livingston Fall 2016 Member of Cal Poly, Team 10-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G6
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 90
All Time: 699
