Ring Video Doorbell Pro Motherboard Replacement
  1. Ring Video Doorbell Pro Motherboard Replacement, Housing: step 1, image 1 of 1
    • Start by using the star-shaped end of the included Ring screwdriver to take out the 5 mm screw on the bottom of the device.
    Ask FixBot
  2. Ring Video Doorbell Pro Motherboard Replacement: step 2, image 1 of 3 Ring Video Doorbell Pro Motherboard Replacement: step 2, image 2 of 3 Ring Video Doorbell Pro Motherboard Replacement: step 2, image 3 of 3
    • Use your thumbs to apply downward pressure on the glass part of the device while pulling the faceplate up and off of the device.
    Ask FixBot
  3. Ring Video Doorbell Pro Motherboard Replacement: step 3, image 1 of 1
    • Using a PH-000 screwdriver, unscrew and set aside all four of these 5.25 mm screws.
    Ask FixBot
  4. Ring Video Doorbell Pro Motherboard Replacement: step 4, image 1 of 2 Ring Video Doorbell Pro Motherboard Replacement: step 4, image 2 of 2
    • Using a plastic pry tool, go along the edge of the device prying the device apart. While doing this, focus on the four clips, two of which are on either side of the device.
    Ask FixBot
  5. Ring Video Doorbell Pro Motherboard Replacement: step 5, image 1 of 1
    • Remove the front of the device from the back plate.
    Ask FixBot
  6. Ring Video Doorbell Pro Motherboard Replacement, Speaker: step 6, image 1 of 1
    • With the Video Doorbell Pro opened up the speaker is exposed.
    Ask FixBot
  7. Ring Video Doorbell Pro Motherboard Replacement: step 7, image 1 of 1
    • Remove this 5.25 mm screw.
    Ask FixBot
  8. Ring Video Doorbell Pro Motherboard Replacement: step 8, image 1 of 1
    • Remove this wire connection by gently prying it off with a plastic pry tool.
    Ask FixBot
  9. Ring Video Doorbell Pro Motherboard Replacement: step 9, image 1 of 1
    • Remove the speaker from the device.
    Ask FixBot
  10. Ring Video Doorbell Pro Motherboard Replacement, Motherboard: step 10, image 1 of 1
    • The next step is to remove the last four connections holding the motherboard in place.
    Ask FixBot
  11. Ring Video Doorbell Pro Motherboard Replacement: step 11, image 1 of 1
    • Using the plastic pry tool, carefully remove this wire connection.
    Ask FixBot
  12. Ring Video Doorbell Pro Motherboard Replacement: step 12, image 1 of 1
    • Using the plastic pry tool, gently ease this ribbon cable from its port.
    Ask FixBot
  13. Ring Video Doorbell Pro Motherboard Replacement: step 13, image 1 of 1
    • Remove the last two wire connections shown here using the same methods utilized in the previous steps.
    Ask FixBot
  14. Ring Video Doorbell Pro Motherboard Replacement: step 14, image 1 of 2 Ring Video Doorbell Pro Motherboard Replacement: step 14, image 2 of 2
    • Using the Phillips 000 screwdriver, remove these three 4.25mm screws.
    Ask FixBot
  15. Ring Video Doorbell Pro Motherboard Replacement: step 15, image 1 of 1
    • Take the motherboard out of the housing. Lift slowly while doing this to make sure the wires and the delicate ribbon cable are not damaged.
    Ask FixBot
To reassemble your device, insert the new motherboard and follow these instructions in reverse order.
10 other people completed this guide.
Jake Dixon
901 Reputation
4 Guides authored
IUPUI, Team S7-G4, Baechle Fall 2017 Member of IUPUI, Team S7-G4, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G4
3 Members
5 Guides authored
4 Guide Comments
Is this the latest model
Phillip - Reply Share
A pig to get apart. Prying the case open needed a glaziers flexy putty knife or spark plug feeler gauge as a plastic pry tool is not man enough . Connectors fall apart as you try to disconnect. Battery, aerial and capacitor are all glued or taped together.
You don’t need to disconnect the ribbon cable in Step 10 unless you intend to remove the camera module, which is screwed to the motherboard so comes away with it
Zam Zoo - Reply Share
thank you very useful - question is i cannot fine a spare main board im after a ring pro mainboard - i open mine and looks like some of the parts are blowen its all green :) do you offer a repair service of main board ?
Sid Hepworth-Lloyd - Reply Share
Where can I buy a new motherboard please?
Vicky_z - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 54
All Time: 10,881
