Ring Video Doorbell Motherboard Replacement
  1. Ring Video Doorbell Motherboard Replacement, Motherboard: step 1, image 1 of 3 Ring Video Doorbell Motherboard Replacement, Motherboard: step 1, image 2 of 3 Ring Video Doorbell Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1 mm screws using the PH00 Phillips Screwdriver.
    Ask FixBot
  2. Ring Video Doorbell Motherboard Replacement: step 2, image 1 of 3 Ring Video Doorbell Motherboard Replacement: step 2, image 2 of 3 Ring Video Doorbell Motherboard Replacement: step 2, image 3 of 3
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
    Ask FixBot
  3. Ring Video Doorbell Motherboard Replacement: step 3, image 1 of 3 Ring Video Doorbell Motherboard Replacement: step 3, image 2 of 3 Ring Video Doorbell Motherboard Replacement: step 3, image 3 of 3
    • Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver.
    • Carefully detach the motherboard, from the housing unit using your hands.
    Ask FixBot
  4. Ring Video Doorbell Motherboard Replacement: step 4, image 1 of 2 Ring Video Doorbell Motherboard Replacement: step 4, image 2 of 2
    • Detach the upper part of the motherboard from the bottom, using your hands.
    Ask FixBot
5 other people completed this guide.
Abdulrahman
709 Reputation
3 Guides authored
USF Tampa, Team S11-G5, Cheng Spring 2018 Member of USF Tampa, Team S11-G5, Cheng Spring 2018
USFT-CHENG-S18S11G5
3 Members
10 Guides authored
1 Guide Comment
Where can you buy a replacement motherboard?
Barry Specter - Reply Share
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 62
All Time: 5,320
