Ring Video Doorbell Battery Replacement
    1. Ring Video Doorbell Battery Replacement, Battery: step 1, image 1 of 3 Ring Video Doorbell Battery Replacement, Battery: step 1, image 2 of 3 Ring Video Doorbell Battery Replacement, Battery: step 1, image 3 of 3
      • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
      • Pry open the aluminium plate using the Plastic Opening Tool(s).
      • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
      Ask FixBot
    2. Ring Video Doorbell Battery Replacement: step 2, image 1 of 3 Ring Video Doorbell Battery Replacement: step 2, image 2 of 3 Ring Video Doorbell Battery Replacement: step 2, image 3 of 3
      • Pry open the back case as shown using the Plastic Opening Tool.
      • Do NOT lift the case of all the way, there is still a cable connecting the two pieces.
      • Disconnect the battery from motherboard by carefully pulling up on the connector.
      Ask FixBot
3 other people completed this guide.
Abdulrahman
709 Reputation
3 Guides authored
USF Tampa, Team S11-G5, Cheng Spring 2018 Member of USF Tampa, Team S11-G5, Cheng Spring 2018
USFT-CHENG-S18S11G5
3 Members
60 Guides authored
7 Guide Comments
Where do I get a replacement battery?
William Price - Reply Share
I had an issue where the battery would not charge the light when I was trying to charge the battery flashed bue quickly, I removed the battery and found that the connector was corroded after cleaning it and making sure it was connected correctly the battery then took a full charge and now the bell functions as intended once again.
P.S thanks for the guide :)
David Haras - Reply Share
Who should the complete unit be sent to for checkup and repairs as it does not work
d.rayyan - Reply Share
can it be sent to the manufacturers for a replacement
similar to David, I pulled off the battery connector and reattached it, then sealed with some rubber cement. Unit immediately went back online.
Daniel Wise - Reply Share
Past 24 Hours: 7
Past 7 Days: 79
Past 30 Days: 338
All Time: 20,536
