Up to 20% off select tools
Ring Video Doorbell Camera Replacement
Views: 21K
View statistics:
Past 24 Hours:
12
Past 7 Days:
46
Past 30 Days:
231
All Time:
21,440
Comments: 14
3 comments on steps, 11 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
In this guide, you will be shown how to take apart and replace the camera of the Ring Video Doorbell step-by-step. You will need a Phillips screwdriver size PH00 and a Plastic Tool Opener.
    1. Ring Video Doorbell  Camera Replacement, Camera: step 1, image 1 of 3 Ring Video Doorbell  Camera Replacement, Camera: step 1, image 2 of 3 Ring Video Doorbell  Camera Replacement, Camera: step 1, image 3 of 3
      • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
      • Pry open the aluminum plate using the Plastic Opening Tool(s).
      • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
      Ask FixBot
    2. Ring Video Doorbell  Camera Replacement: step 2, image 1 of 3 Ring Video Doorbell  Camera Replacement: step 2, image 2 of 3 Ring Video Doorbell  Camera Replacement: step 2, image 3 of 3
      • Pry open the back case as shown using the Plastic Opening Tool.
      • Disconnect the battery from motherboard by carefully pulling up on the connector.
      Ask FixBot
    3. Ring Video Doorbell  Camera Replacement: step 3, image 1 of 3 Ring Video Doorbell  Camera Replacement: step 3, image 2 of 3 Ring Video Doorbell  Camera Replacement: step 3, image 3 of 3
      • Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver.
      • Carefully detach the motherboard, from the housing unit using your hands.
      Ask FixBot
    4. Ring Video Doorbell  Camera Replacement: step 4, image 1 of 2 Ring Video Doorbell  Camera Replacement: step 4, image 2 of 2
      • Using the Plating Tool Opener, arefully disconnect the ribbon cable that attaches the camera to the housing.
      • Replace camera, and follow the steps in reverse order to reassemble
      Ask FixBot
    5. Ring Video Doorbell  Camera Replacement: step 5, image 1 of 2 Ring Video Doorbell  Camera Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Unscrew the two 1 mm screws using the PH00 Philips Screwdriver.
      • Detach the black and red wire connected to the motherboard, using the tweezers, to remove the camera.
      Ask FixBot
3 other people completed this guide.
Author
with
Isaiah Wilson
231 Reputation
1 Guide authored
USF Tampa, Team S11-G5, Cheng Spring 2018 Member of USF Tampa, Team S11-G5, Cheng Spring 2018
USFT-CHENG-S18S11G5
3 Members
60 Guides authored
11 Guide Comments
What camera should I use to replace a malfunctioning camera in the ring video doorbell? And where do I buy it?
jonathan.byus - Reply Share
Bump. What camera should I use to replace? (Scratched Lens.) Is the lens you can touch, a lens, or is it just a cover? Mine fell at there is chip right in the center that make the image unusable.
Bobby Diggins - Reply Share
I have a scratch dead center of mine too. Have no clue how it got there as I’m super careful when I take it off to charge. Ugh. did you find out where to buy a replacement?
Kim Townsend - Reply Share
What camera should I use to replace? (Scratched Lens.)  I have the right 1st generation with a 740p camera
meanltltoo - Reply Share
Has anyone found a replacement camera online?
christina.stewart - Reply Share
Past 24 Hours: 12
Past 7 Days: 46
Past 30 Days: 231
All Time: 21,440
