Ring Stick Up Cam Camera Replacement
Views: 5.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
74
All Time:
5,537
Comments: 5
3 comments on steps, 2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
In this guide, we will show you how to replace the camera in a Ring Stick Up Cam. You will need a Phillips #00 screwdriver and a plastic opening tool.
Tools
    1. Ring Stick Up Cam Camera Replacement, Battery: step 1, image 1 of 1
      • Remove the six 6mm Phillips #00 screws from the back of the device.
      Ask FixBot
    2. Ring Stick Up Cam Camera Replacement: step 2, image 1 of 1
      • Pry off the aluminum plate using a plastic opening tool.
      Ask FixBot
    3. Ring Stick Up Cam Camera Replacement: step 3, image 1 of 1
      • Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
      Ask FixBot
    4. Ring Stick Up Cam Camera Replacement: step 4, image 1 of 1
      • Pry off the back cover using a plastic opening tool.
      Ask FixBot
    5. Ring Stick Up Cam Camera Replacement: step 5, image 1 of 1
      • Disconnect the battery power leads using a plastic opening tool.
      Ask FixBot
    6. Ring Stick Up Cam Camera Replacement: step 6, image 1 of 1
      • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
      Ask FixBot
    1. Ring Stick Up Cam Camera Replacement, Camera: step 7, image 1 of 1
      • Remove the three silver 6mm Phillips #00 screws holding the motherboard in the device.
      Ask FixBot
    2. Ring Stick Up Cam Camera Replacement: step 8, image 1 of 1
      • Disconnect the ribbon connector shown in the photo.
      Ask FixBot
    3. Ring Stick Up Cam Camera Replacement: step 9, image 1 of 1
      • Remove the motherboard from the device by hand.
      Ask FixBot
    4. Ring Stick Up Cam Camera Replacement: step 10, image 1 of 1
      • Remove the two black 5mm Phillips #00 screws holding the camera board into the device.
      • Remove the single silver 10mm Phillips #00 screw holding the camera board into the device.
      Ask FixBot
    5. Ring Stick Up Cam Camera Replacement: step 11, image 1 of 1
      • Remove the three plastic spacers shown in the photo by hand.
      Ask FixBot
    6. Ring Stick Up Cam Camera Replacement: step 12, image 1 of 1
      • Carefully disconnect the camera board from the daughterboard by sliding a plastic opening tool between the camera board and the daughterboard.
      Ask FixBot
    7. Ring Stick Up Cam Camera Replacement: step 13, image 1 of 1
      • Lift the camera board out of the housing using your hand.
      Ask FixBot
Ao Li
245 Reputation
1 Guide authored
UC Davis, Team S18-G3, Lore Winter 2019 Member of UC Davis, Team S18-G3, Lore Winter 2019
UCD-LORE-W19S18G3
3 Members
48 Guides authored
2 Guide Comments
Where can I purchase a new lens?
Javier Casas - Reply Share
Any ideas where to get a new lens?
Mete Doguoglu - Reply Share
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 74
All Time: 5,537
