Ring Outdoor Security Cam Battery Replacement
    1. Ring Outdoor Security Cam Battery Replacement, Battery: step 1, image 1 of 1
      • Remove the six 6 mm Phillips #00 screws from the back on the device.
      Ask FixBot
    2. Ring Outdoor Security Cam Battery Replacement: step 2, image 1 of 1
      • Pry off the aluminum plate using a plastic opening tool.
      Ask FixBot
    3. Ring Outdoor Security Cam Battery Replacement: step 3, image 1 of 1
      • Using the same tool pry the back plate off of the device.
      Ask FixBot
    4. Ring Outdoor Security Cam Battery Replacement: step 4, image 1 of 1
      • Disconnect the battery power leads using a plastic opening tool.
      Ask FixBot
    5. Ring Outdoor Security Cam Battery Replacement: step 5, image 1 of 1
      • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 26
All Time: 1,407
