Ring Floodlight Cam Motherboard Replacement
    1. Ring Floodlight Cam Motherboard Replacement, Motherboard: step 1, image 1 of 2 Ring Floodlight Cam Motherboard Replacement, Motherboard: step 1, image 2 of 2
      • Remove the external cover with a Jimmy tool.
      Ask FixBot
    2. Ring Floodlight Cam Motherboard Replacement: step 2, image 1 of 2 Ring Floodlight Cam Motherboard Replacement: step 2, image 2 of 2
      • Remove the four outer cover 4.5mm screws with a Philips 1 screwdriver.
      Ask FixBot
    3. Ring Floodlight Cam Motherboard Replacement: step 3, image 1 of 1
      • Remove the internal cover.
      Ask FixBot
    4. Ring Floodlight Cam Motherboard Replacement: step 4, image 1 of 1
      • Disconnect the flexible flat cable (FFC) from the motherboard.
      Ask FixBot
    5. Ring Floodlight Cam Motherboard Replacement: step 5, image 1 of 1
      • Remove the three-prong connector with angled tweezers.
      Ask FixBot
    6. Ring Floodlight Cam Motherboard Replacement: step 6, image 1 of 1
      • Remove the 2mm screws with a Phillips #00 screwdriver.
      Ask FixBot
    7. Ring Floodlight Cam Motherboard Replacement: step 7, image 1 of 2 Ring Floodlight Cam Motherboard Replacement: step 7, image 2 of 2
      • Remove the power supply.
      • Disconnect the power supply from the device.
      Ask FixBot
    8. Ring Floodlight Cam Motherboard Replacement: step 8, image 1 of 1
      • Remove the 2mm screws with a Phillips 00 screwdriver from the base connector.
      • From this step forward use a low profile wrench instead of a screwdriver with the correct bit size to remove screws non-destructively.
      Ask FixBot
    9. Ring Floodlight Cam Motherboard Replacement: step 9, image 1 of 2 Ring Floodlight Cam Motherboard Replacement: step 9, image 2 of 2
      • Drill holes into the exterior with a 1/16 drill bit.
      • Skip this step unless you lack the specialized tools or other attempts to remove screws non destructively were unsuccessful.
      Ask FixBot
    10. Ring Floodlight Cam Motherboard Replacement: step 10, image 1 of 1
      • Unscrew the 2mm screws on the metal baseplate with a Phillips 00 screwdriver.
      Ask FixBot
    11. Ring Floodlight Cam Motherboard Replacement: step 11, image 1 of 1
      • Remove the metal baseplate.
      Ask FixBot
    12. Ring Floodlight Cam Motherboard Replacement: step 12, image 1 of 1
      • Remove the power connector from the motherboard using angled tweezers.
      Ask FixBot
    13. Ring Floodlight Cam Motherboard Replacement: step 13, image 1 of 1
      • Remove the front-end flexible flat cable (FFC) with angled tweezers.
      Ask FixBot
    14. Ring Floodlight Cam Motherboard Replacement: step 14, image 1 of 1
      • Remove the motion sensor flat flexible cable (FFC).
      Ask FixBot
    15. Ring Floodlight Cam Motherboard Replacement: step 15, image 1 of 2 Ring Floodlight Cam Motherboard Replacement: step 15, image 2 of 2
      • Remove the motherboard module.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order and at step 8 fill in the drill holes with plastic putty to reseal device.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Ethan McCrory
291 Reputation
1 Guide authored
Texas Tech, Team 41-3, Johansen Spring 2026 Member of Texas Tech, Team 41-3, Johansen Spring 2026
TTU-JOHANSEN-S26S41G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 43
All Time: 188
