Shop the Holiday Gift Guide
Ring Doorbell 1st Generation Battery Replacement
Views: 217K
View statistics:
Past 24 Hours:
15
Past 7 Days:
129
Past 30 Days:
555
All Time:
216,998
Comments: 67
8 comments on steps, 59 guide comments.
Go to guide comments
Completed: 34
34 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 40 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide is to show how to open the Ring Doorbell to replace the battery. This is only for the 1st gen ring doorbells as newer versions do not have a battery and require full time power.
Parts
Tools
Video Overview
    1. Ring Doorbell 1st Generation Battery Replacement, Face plate removal: step 1, image 1 of 1
      • Start by removing the 4 screws to take off the aluminum face-plate.
      Ask FixBot
    2. Ring Doorbell 1st Generation Battery Replacement: step 2, image 1 of 2 Ring Doorbell 1st Generation Battery Replacement: step 2, image 2 of 2
      • Pry the aluminum face-plate carefully using a plastic spudger while applying gentle pressure. This will reveal the 4 black screws underneath.
      • You will need a micro phillips screwdriver to remove these tiny screws. You will find that it requires considerable torque to loosen them, so to avoid stripping the head, really push in with the screwdriver while applying torque.
      Ask FixBot
    3. Ring Doorbell 1st Generation Battery Replacement: step 3, image 1 of 1
      • Carefully pry the plastic cover with a pick to pop the insert out. Watch the micro USB port that is sticking out.
      Ask FixBot
    4. Ring Doorbell 1st Generation Battery Replacement: step 4, image 1 of 1
      • Gently pry up the battery from underneath the connector. But remember the orientation, red wires to the outside exposed wire on the connector facing upward.
      • The battery MAY still be attached to the plate. Buy some double sided tape, because disposal of the old battery will likely include the existing tape.
      Ask FixBot
    5. Ring Doorbell 1st Generation Battery Replacement: step 5, image 1 of 1
      • Two Lithium polymer batteries are connected back to back and in parallel to the regulator. The batteries are rated at 9.47w @ 3.75v each.
      • When you are satisfied that the battery is properly installed, the new battery should have enough charge that you will see at least one of several LED's light up. You can then close up. But if not, charge the unit via USB to see if the LED's are functioning. If not, check the battery connection.
      Ask FixBot
34 other people completed this guide.
Author
with
Greg Beeblebrox
1,331 Reputation
2 Guides authored
59 Guide Comments
This is one of the few products that it's rarely if ever necessary to replace a battery in, as the warranty will cover a rapidly draining or not-charging battery. I'm glad you didn't tear down your chime, too! ;)
pyrodice - Reply Share
disagree. my battery went.
ralph - Reply Share
Without a doubt there is a fault with the batteries on these 2020 5UM5E5 models. I’ve just had to replace the battery in mine. Bought from here.
https://www.ebay.co.uk/itm/304494747020?...
Matt Crooke - Reply Share
Where can the battery be purchased?
Mike Menendez - Reply Share
ralph - Reply Share
Past 24 Hours: 15
Past 7 Days: 129
Past 30 Days: 555
All Time: 216,998
