Rimless Glasses Temple Replacement
Views: 16K
View statistics:
Past 24 Hours:
11
Past 7 Days:
97
Past 30 Days:
394
All Time:
16,323
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will provide a clear step-wise procedure on how to repair a broken temple (arm) on a pair of rimless glasses. Glasses can be bent or broken in all sorts of ways, and wearers of spectacles are surely familiar with the plight of a damaged frame.
This is a very simple process which can save you money when you need to fix your rimless glasses at home. Every time a displacement occurs, you’ll be able to fix your glasses on your own. All you need to have is a rimless glasses repair tool kit which consists of a glasses plier, a silhousette, a push pin, and compression glove.
    1. Rimless Glasses Temple Replacement, Rimless Glasses Temple Replacement: step 1, image 1 of 3 Rimless Glasses Temple Replacement, Rimless Glasses Temple Replacement: step 1, image 2 of 3 Rimless Glasses Temple Replacement, Rimless Glasses Temple Replacement: step 1, image 3 of 3
      • Take the compression sleeves and insert them into the outer lens holes with the pins facing out.
      Ask FixBot
    2. Rimless Glasses Temple Replacement: step 2, image 1 of 2 Rimless Glasses Temple Replacement: step 2, image 2 of 2
      • Using the cutting head of the glasses plier, trim the compression sleeve pins down so that only 1 mm remains sticking out the front of the glasses.
      • Take a push pin and enlarge the holes of compression sleeves by gently inserting the pin into the holes.
      Ask FixBot
    3. Rimless Glasses Temple Replacement: step 3, image 1 of 3 Rimless Glasses Temple Replacement: step 3, image 2 of 3 Rimless Glasses Temple Replacement: step 3, image 3 of 3
      • Insert the arm of the glasses into the enlarged holes of the compression sleeves.
      • Use a silhousette to gently press the arm from the top and tighten it to the glasses.
      Ask FixBot
3 other people completed this guide.
2 Guide Comments
This is very good if the frame arm just fell off of the lens, but it doesn't tell how to remove a broken frame arm from the lens—ie, how to get the compression sleeve off of the broken arm without damaging the lens.
JM MJ - Reply Share
for new lenses what are the hole centres for 2 pin please?
hoare - Reply Share
Past 24 Hours: 11
Past 7 Days: 97
Past 30 Days: 394
All Time: 16,323
