Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Tools
T15 Torx Screwdriver$7.99
Introduction
Go to step 1 ↓The trigger is a multi-speed switch and requires replacing the whole assembly. Soldering is necessary for this guide. Please familiarize yourself with the iFixit guide on Soldering before starting.
Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
Rotate the casing until it fits onto the housing with no gaps between it and the clear cover.
Identify the LED light. The LED light is the component with clear casing and has two wires attached, located toward the bottom of the driver.
