Introduction
If you blow a fuse in the impact driver you only have to open up the device and replace the broken fuse with a new one.
Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
Rotate the casing until it fits onto the housing with no gaps between it and the clear cover.
Identify the translucent orange fuse cartridge connected by a thick red wire and a thick white wire.
