Ridgid R86008 Gearbox Replacement
  1. Ridgid R86008 Gearbox Replacement, Gearbox: step 1, image 1 of 1
    • Before you begin make sure battery is removed from drill.
    • Loosen the four 13mm T10 Torx screws from the back of the drill and remove cap.
    Ask FixBot
  2. Ridgid R86008 Gearbox Replacement: step 2, image 1 of 1
    • Remove the two 25mm T10 Torx screws from the front of the drill.
    Ask FixBot
  3. Ridgid R86008 Gearbox Replacement: step 3, image 1 of 1
    • Remove the remaining 13mm T10 Torx screws and pull apart drill case.
    Ask FixBot
  4. Ridgid R86008 Gearbox Replacement: step 4, image 1 of 1
    • Identify gearbox.
    Ask FixBot
  5. Ridgid R86008 Gearbox Replacement: step 5, image 1 of 3 Ridgid R86008 Gearbox Replacement: step 5, image 2 of 3 Ridgid R86008 Gearbox Replacement: step 5, image 3 of 3
    • Using a PH1 screwdriver, remove the four 13mm PH screws from the back of the gearbox.
    • It may be easier to unscrew the screws by separating the front end of the drill from the rest of the drill.
    Ask FixBot
  6. Ridgid R86008 Gearbox Replacement: step 6, image 1 of 1
    • Pull apart gearbox.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 35
All Time: 1,055
