Ridgid R4021 Blade Replacement
    1. Ridgid R4021 Blade Replacement, Saw Blade: step 1, image 1 of 3 Ridgid R4021 Blade Replacement, Saw Blade: step 1, image 2 of 3 Ridgid R4021 Blade Replacement, Saw Blade: step 1, image 3 of 3
      • Remove the top panel to access the saw blade.
      • Ensure any debris is cleared from the blade area.
      Ask FixBot
    2. Ridgid R4021 Blade Replacement: step 2, image 1 of 2 Ridgid R4021 Blade Replacement: step 2, image 2 of 2
      • Remove the two included wrenches located on the right side of the unit.
      Ask FixBot
    3. Ridgid R4021 Blade Replacement: step 3, image 1 of 3 Ridgid R4021 Blade Replacement: step 3, image 2 of 3 Ridgid R4021 Blade Replacement: step 3, image 3 of 3
      • Fit the larger wrench around the nut on saw blade.
      • Fasten the smaller wrench to the screw coming through the blade.
      • Twist the bigger lever counter-clockwise while holding the smaller wrench in order to remove the nut.
      Ask FixBot
    4. Ridgid R4021 Blade Replacement: step 4, image 1 of 2 Ridgid R4021 Blade Replacement: step 4, image 2 of 2
      • Remove the saw blade by tilting it away from the well wall.
      • Use caution when handling the saw blade.
      Ask FixBot
    5. Ridgid R4021 Blade Replacement: step 5, image 1 of 2 Ridgid R4021 Blade Replacement: step 5, image 2 of 2
      • Place the new blade on the screw the same way the other blade was removed.
      • You can put the old blade in the new packaging to ensure safety.
      Ask FixBot
Obelia Abarca
345 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 73
All Time: 3,844
