Ridgid R2601 Motor Assembly Replacement
  1. Ridgid R2601 Motor Assembly Replacement, Top Cover: step 1, image 1 of 1
    • Remove the four M3.5 x 16 mm screws from the top cover using a Torx T10 screwdriver.
    Ask FixBot
  2. Ridgid R2601 Motor Assembly Replacement: step 2, image 1 of 1
    • Pull off the top cover.
    Ask FixBot
  3. Ridgid R2601 Motor Assembly Replacement, Bearing: step 3, image 1 of 1
    • Turn the sander upside down so that the base faces you.
    • Remove the four 6.4 mm screws from the bottom of the base using a Torx T-25 screwdriver.
    Ask FixBot
  4. Ridgid R2601 Motor Assembly Replacement: step 4, image 1 of 1
    • Remove the base.
    Ask FixBot
  5. Ridgid R2601 Motor Assembly Replacement: step 5, image 1 of 1
    • Remove the 10 mm screw from the center of the bearing using a Torx T-20 screwdriver.
    Ask FixBot
  6. Ridgid R2601 Motor Assembly Replacement: step 6, image 1 of 1
    • Remove the bearing.
    Ask FixBot
  7. Ridgid R2601 Motor Assembly Replacement, Brake: step 7, image 1 of 1
    • Remove the four 16mm screws from the side of the sander using a Torx T20 screwdriver.
    Ask FixBot
  8. Ridgid R2601 Motor Assembly Replacement: step 8, image 1 of 1
    • Use a metal spudger to open the sander's plastic housing.
    Ask FixBot
  9. Ridgid R2601 Motor Assembly Replacement: step 9, image 1 of 1
    • Remove the plastic housing.
    Ask FixBot
  10. Ridgid R2601 Motor Assembly Replacement: step 10, image 1 of 1
    • Remove the brake from its slot in the housing.
    Ask FixBot
  11. Ridgid R2601 Motor Assembly Replacement, Motor Assembly: step 11, image 1 of 1
    • Remove the metal flywheel.
    Ask FixBot
  12. Ridgid R2601 Motor Assembly Replacement: step 12, image 1 of 1
    • Rotate the sander so that the top is facing you.
    • Remove the power switch.
    Ask FixBot
  13. Ridgid R2601 Motor Assembly Replacement: step 13, image 1 of 2 Ridgid R2601 Motor Assembly Replacement: step 13, image 2 of 2
    • Use a T20 Torx screwdrivers to remove the four 11.11mm screws from the motor housing.
    • Use a T25 Torx screwdriver to remove the two 12.7mm screws next to the leads.
    Ask FixBot
  14. Ridgid R2601 Motor Assembly Replacement: step 14, image 1 of 1
    Tool used on this step:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Buy
    • Use a 2.5mm flathead screwdriver to loosen but not remove the screws holding the wiring leading to the speed controller.
    Ask FixBot
  15. Ridgid R2601 Motor Assembly Replacement: step 15, image 1 of 1
    • Remove the leads.
    Ask FixBot
  16. Ridgid R2601 Motor Assembly Replacement: step 16, image 1 of 1
    • Remove the motor housing.
    Ask FixBot
  17. Ridgid R2601 Motor Assembly Replacement: step 17, image 1 of 1
    • Remove the motor.
    Ask FixBot
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 29
All Time: 1,237
