Ridgid R2601 Bearing Replacement
  1. Ridgid R2601 Bearing Replacement, Bearing: step 1, image 1 of 1
    • Turn the sander upside down so that the base faces you.
    • Remove the four 6.4 mm screws from the bottom of the base using a Torx T-25 screwdriver.
    Ask FixBot
  2. Ridgid R2601 Bearing Replacement: step 2, image 1 of 1
    • Remove the base.
    Ask FixBot
  3. Ridgid R2601 Bearing Replacement: step 3, image 1 of 1
    • Remove the 10 mm screw from the center of the bearing using a Torx T-20 screwdriver.
    Ask FixBot
  4. Ridgid R2601 Bearing Replacement: step 4, image 1 of 1
    • Remove the bearing.
    Ask FixBot
5 Guide Comments
What is the bearing size?
Dagan Larson - Reply Share
The actual bearing appears to be an R002RS.
ID 15mm
OD 32mm
Width: 9mm
I used a large socket to push the bearing out of the squarish bracket. The bearing needs to be pushed out from top to bottom (as it would be oriented when the sander is sitting upright on a surface).
I placed the socket inside the opening in the top, and put screws into the bottom (I happened to have some longer screws with the same thread pitch) to provide clearance for the bearing to come out. Then I pressed it with a vise. Tapping the socket with a hammer would also work.
Joe Porkka - Reply Share
Shouldn't the title be "How to remove a bearing housing"? You don't give any instructions on how to actually remove the bearing from the housing, nor how to insert a new bearing into the housing and reassembly.
I'm sorry, but it feels like you got part way into the instructions, got bored and said, "eh, it's good enough."
Ichabod - Reply Share
How do you know if the bearings bad? Mine spins ok seems even, no sounds coming from it, the pad spins really slow if I put any pressure, even just with the weight of the sander
Nick Wilkens - Reply Share
I definitely agree with the other comments, this repair guide is no help at all. I need to know how I should properly prevent the shaft from spinning to remove the screw that holds the bearing in place. I could just jam something into the fins that pull dust away but I figured a repair guide would tell how to do it without damaging the sander.
Trevor Callan - Reply Share
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 70
All Time: 2,773
