Ridgid GEN5X R8642 Switch Replacement
  1. Ridgid GEN5X R8642 Switch Replacement, Switch: step 1, image 1 of 1
    • Remove the plastic tab holding the handle cover in place by prying upward with the spudger until the tab pops off.
    Ask FixBot
  2. Ridgid GEN5X R8642 Switch Replacement: step 2, image 1 of 1
    • Remove the handle cover by pulling it towards the front of the saw.
    • The grip can sometimes become stuck and may require a decent amount of force to remove.
    Ask FixBot
  3. Ridgid GEN5X R8642 Switch Replacement: step 3, image 1 of 2 Ridgid GEN5X R8642 Switch Replacement: step 3, image 2 of 2
    • Use a T20 Torx screwdriver to remove the nine M4 X 16mm screws from the plastic housing.
    Ask FixBot
  4. Ridgid GEN5X R8642 Switch Replacement: step 4, image 1 of 1
    • Use a JIS #1 screwdriver to remove the two M4 x 25mm screws on both sides of the metal housing.
    Ask FixBot
  5. Ridgid GEN5X R8642 Switch Replacement: step 5, image 1 of 1
    • Remove one half of the plastic housing using a spudger so that the internal system is exposed.
    Ask FixBot
  6. Ridgid GEN5X R8642 Switch Replacement: step 6, image 1 of 1
    • Remove the plastic wire covers to the red and black connections on the switch assembly.
    Ask FixBot
  7. Ridgid GEN5X R8642 Switch Replacement: step 7, image 1 of 1
    • Remove the soldered connection from the switch assembly.
    Ask FixBot
  8. Ridgid GEN5X R8642 Switch Replacement: step 8, image 1 of 1
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 35
All Time: 639
