Ridgid GEN5X R8642 Motor Replacement
  1. Ridgid GEN5X R8642  Motor Replacement, Motor Replacement: step 1, image 1 of 1
    • Remove the plastic tab holding the handle cover in place by prying upward with the spudger until the tab pops off.
    Ask FixBot
  2. Ridgid GEN5X R8642  Motor Replacement: step 2, image 1 of 1
    • Remove the handle cover by pulling it towards the front of the saw.
    • The grip can sometimes become stuck and may require a decent amount of force to remove.
    Ask FixBot
  3. Ridgid GEN5X R8642  Motor Replacement: step 3, image 1 of 2 Ridgid GEN5X R8642  Motor Replacement: step 3, image 2 of 2
    • Use a T20 Torx screwdriver to remove the nine M4 X 16mm screws from the plastic housing.
    Ask FixBot
  4. Ridgid GEN5X R8642  Motor Replacement: step 4, image 1 of 1
    • Use a JIS #1 screwdriver to remove the two M4 x 25mm screws on both sides of the metal housing.
    Ask FixBot
  5. Ridgid GEN5X R8642  Motor Replacement: step 5, image 1 of 2 Ridgid GEN5X R8642  Motor Replacement: step 5, image 2 of 2
    • Remove one half of the plastic housing using a spudger so that the internal system is exposed.
    Ask FixBot
  6. Ridgid GEN5X R8642  Motor Replacement: step 6, image 1 of 2 Ridgid GEN5X R8642  Motor Replacement: step 6, image 2 of 2
    • Remove the one 16mm T20 screw that holds the grip support onto the saw.
    Ask FixBot
  7. Ridgid GEN5X R8642  Motor Replacement: step 7, image 1 of 3 Ridgid GEN5X R8642  Motor Replacement: step 7, image 2 of 3 Ridgid GEN5X R8642  Motor Replacement: step 7, image 3 of 3
    • Remove the five T20 Torx screws from the gear assembly cover and pull the cover off.
    Ask FixBot
  8. Ridgid GEN5X R8642  Motor Replacement: step 8, image 1 of 2 Ridgid GEN5X R8642  Motor Replacement: step 8, image 2 of 2
    • Carefully remove the motor making sure not to harm any of the wires that are attached. Place motor gently out of the way.
    Ask FixBot
  9. Ridgid GEN5X R8642  Motor Replacement: step 9, image 1 of 1
    • Remove the plastic wire covers to the red and black connections on the switch assembly.
    • When you remove the wire covers, you should be able to see the solder on the wires.
    • Desolder the connections on both the red and black wire using a soldering iron.
    • Once the solder is removed, pull out the wires with the battery port attached to the wires.
    Ask FixBot
  10. Ridgid GEN5X R8642  Motor Replacement: step 10, image 1 of 1
    • Remove the soldered connection from the switch assembly.
    Ask FixBot
  11. Ridgid GEN5X R8642  Motor Replacement: step 11, image 1 of 2 Ridgid GEN5X R8642  Motor Replacement: step 11, image 2 of 2
    • Solder both connections of the new motor replacement to the switch assembly.
    Ask FixBot
To reassemble your device follow these instructions in reverse order.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 816
