Riddell Speedflex Football Helmet Cam-Loc System Replacement
    1. Riddell Speedflex Football Helmet Cam-Loc System Replacement, Cam-Loc System: step 1, image 1 of 2 Riddell Speedflex Football Helmet Cam-Loc System Replacement, Cam-Loc System: step 1, image 2 of 2
      • Place your helmet on a reliable, flat, sturdy surface to ensure an easy removal and replacement process.
      • Position the helmet so you can see the bowl part of the helmet.
      Ask FixBot
    2. Riddell Speedflex Football Helmet Cam-Loc System Replacement: step 2, image 1 of 3 Riddell Speedflex Football Helmet Cam-Loc System Replacement: step 2, image 2 of 3 Riddell Speedflex Football Helmet Cam-Loc System Replacement: step 2, image 3 of 3
      • Place your hand near the earhole padding; this is where you will find the cam-loc thumbscrew.
      • The thumbscrew is a black circular piece with a ridged border.
      • With two fingers, unscrew the thumbscrew until it detaches.
      • This is where you may use the optional Riddell Quick Release Tool if desired.
      • Make sure your free fingers are holding onto the cam-loc system. If not, the cam-loc system may fall from the helmet.
      • Pull the cam-loc system from the helmet and place it to the side.
      Ask FixBot
    3. Riddell Speedflex Football Helmet Cam-Loc System Replacement: step 3, image 1 of 2 Riddell Speedflex Football Helmet Cam-Loc System Replacement: step 3, image 2 of 2
      • Repeat step 2 for the cam-loc system on the other side of the helmet.
      • Make sure your free fingers are holding onto the cam-loc system. As mentioned earlier, the cam-loc system has the potential to fall.
      Ask FixBot
To ensure the quality of the replacement, try the helmet on and run your facemask through some testing.
Peyton Washburn
674 Reputation
5 Guides authored
Texas Tech, Team 41-6, Allen Fall 2025 Member of Texas Tech, Team 41-6, Allen Fall 2025
TTU-ALLEN-F25S41G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 42
All Time: 151
