Ricoh YF-20 Super Lens Replacement
  1. Ricoh YF-20 Super Lens Replacement, Front Cover: step 1, image 1 of 2 Ricoh YF-20 Super Lens Replacement, Front Cover: step 1, image 2 of 2
    • Use the screwdriver to unscrew the indicated screws from the left, right, bottom, and back sides of the camera.
    Ask FixBot
  2. Ricoh YF-20 Super Lens Replacement: step 2, image 1 of 3 Ricoh YF-20 Super Lens Replacement: step 2, image 2 of 3 Ricoh YF-20 Super Lens Replacement: step 2, image 3 of 3
    • Loosen the back cover from both the left and the right sides of the camera. Take off the back cover.
    • The lid of the battery compartment may fall off because it is not attached to anything.
    Ask FixBot
  3. Ricoh YF-20 Super Lens Replacement: step 3, image 1 of 3 Ricoh YF-20 Super Lens Replacement: step 3, image 2 of 3 Ricoh YF-20 Super Lens Replacement: step 3, image 3 of 3
    • Open the film compartment.
    • Press your finger on top of the grey latch on the left side of the camera.
    Ask FixBot
  4. Ricoh YF-20 Super Lens Replacement: step 4, image 1 of 3 Ricoh YF-20 Super Lens Replacement: step 4, image 2 of 3 Ricoh YF-20 Super Lens Replacement: step 4, image 3 of 3
    • Removing the film compartment door is optional. However, it may aid maneuverability in future steps.
    • Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place.
    • Use your fingers to completely remove the metal pin.
    • Remove the film compartment door.
    Ask FixBot
  5. Ricoh YF-20 Super Lens Replacement: step 5, image 1 of 2 Ricoh YF-20 Super Lens Replacement: step 5, image 2 of 2
    • Use a thin shaft screwdriver and unscrew the two indicated screws within the film compartment.
    Ask FixBot
  6. Ricoh YF-20 Super Lens Replacement: step 6, image 1 of 3 Ricoh YF-20 Super Lens Replacement: step 6, image 2 of 3 Ricoh YF-20 Super Lens Replacement: step 6, image 3 of 3
    • Loosen the front cover from the left and right sides of the camera.
    • Take off the front cover.
    Ask FixBot
  7. Ricoh YF-20 Super Lens Replacement, Lens: step 7, image 1 of 3 Ricoh YF-20 Super Lens Replacement, Lens: step 7, image 2 of 3 Ricoh YF-20 Super Lens Replacement, Lens: step 7, image 3 of 3
    • The lens is only attached to the main camera body. Set the front and back covers aside.
    • Unscrew three screws from the outermost plastic plate covering the lens.
    • After the screws are removed, the outermost plate can be removed.
    Ask FixBot
  8. Ricoh YF-20 Super Lens Replacement: step 8, image 1 of 3 Ricoh YF-20 Super Lens Replacement: step 8, image 2 of 3 Ricoh YF-20 Super Lens Replacement: step 8, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the ring shaped metal brace.
    • Using fingers or tweezers, remove the lens from the camera.
    Ask FixBot
Eric Dazet
352 Reputation
5 Guides authored
Cal Poly, Team 6-21, Amido Spring 2012 Member of Cal Poly, Team 6-21, Amido Spring 2012
CPSU-AMIDO-S12S6G21
4 Members
26 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 35
All Time: 1,126
