Ricoh Theta Z1 Battery Replacement
  1. Ricoh Theta Z1 Battery Replacement, Bottom: step 1, image 1 of 3 Ricoh Theta Z1 Battery Replacement, Bottom: step 1, image 2 of 3 Ricoh Theta Z1 Battery Replacement, Bottom: step 1, image 3 of 3
    • Use a Spudger to remove the sticker, starting from the reset hole.
    • The using 00-Torx remove the 3 screws at the bottom.
    Ask FixBot
  2. Ricoh Theta Z1 Battery Replacement, Button side: step 2, image 1 of 2 Ricoh Theta Z1 Battery Replacement, Button side: step 2, image 2 of 2
    • Now remove the screw at the side with the 00-Torx screwdriver.
    • Gently remove the side pieces.
    Ask FixBot
  3. Ricoh Theta Z1 Battery Replacement, Long side: step 3, image 1 of 2 Ricoh Theta Z1 Battery Replacement, Long side: step 3, image 2 of 2
    • Remove the 00-Torx screw and gently slide the side piece off.
    Ask FixBot
  4. Ricoh Theta Z1 Battery Replacement, Long Side: step 4, image 1 of 2 Ricoh Theta Z1 Battery Replacement, Long Side: step 4, image 2 of 2
    • Remove the 4 00-Phillips screws from the long side
    Ask FixBot
  5. Ricoh Theta Z1 Battery Replacement, Button Side: step 5, image 1 of 2 Ricoh Theta Z1 Battery Replacement, Button Side: step 5, image 2 of 2
    • Remove the 3 00-Phillips screws from the button side
    Ask FixBot
  6. Ricoh Theta Z1 Battery Replacement, Opening the Case: step 6, image 1 of 2 Ricoh Theta Z1 Battery Replacement, Opening the Case: step 6, image 2 of 2
    • Now one part of the case can be pulled away, carefully observing the pin for the strap holder.
    Ask FixBot
  7. Ricoh Theta Z1 Battery Replacement, Replacing the Battery: step 7, image 1 of 3 Ricoh Theta Z1 Battery Replacement, Replacing the Battery: step 7, image 2 of 3 Ricoh Theta Z1 Battery Replacement, Replacing the Battery: step 7, image 3 of 3
    • The battery is glued with tape to a holder, that has to be unscrewed.
    Ask FixBot
2 other people completed this guide.
JJAY
230 Reputation
1 Guide authored
6 Guide Comments
Great guide, thanks. May i know the battery detail that you use for the replacement.
Hanifah Mazlan - Reply Share
Hi Hanifah!
The battery is called "DB-110" by Ricoh, but there are similar models with other names. If you click on the link "LI‑92B" in the parts list you get all the details.
JJAY - Reply Share
πŸ‘ This was so helpful and easy to do ! Thank you πŸ˜€ * Bought DB 110 (same as for Ricoh Theta X) on Amazon for 49 €
Maximilian Paech - Reply Share
Thank you for your post. I just called Ricoh for assistance and was referred to www.precisioncamera.com/ricoh, where I was quoted $833 to replace the battery.
I have just ordered a replacement battery on Amazon and will be doing it myself. Ricoh and PrecisionCamera can go FYT!
Mtherofdragons - Reply Share
Where can I find the specific 00 torx screwdriver?
512SRH - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 74
All Time: 2,603
