Ricoh Super 8 800z Handle Assembly Replacement
  1. Ricoh Super 8 800z Handle Assembly Replacement, Handle Assembly: step 1, image 1 of 3 Ricoh Super 8 800z Handle Assembly Replacement, Handle Assembly: step 1, image 2 of 3 Ricoh Super 8 800z Handle Assembly Replacement, Handle Assembly: step 1, image 3 of 3
    • Open the handle's battery compartment and remove the batteries from the handle.
    Ask FixBot
  2. Ricoh Super 8 800z Handle Assembly Replacement: step 2, image 1 of 3 Ricoh Super 8 800z Handle Assembly Replacement: step 2, image 2 of 3 Ricoh Super 8 800z Handle Assembly Replacement: step 2, image 3 of 3
    • Using the Phillips #000 screwdriver, remove the three screws on the round plate on the right side of the camera handle. This is the side with the handle lock release button.
    Ask FixBot
  3. Ricoh Super 8 800z Handle Assembly Replacement: step 3, image 1 of 3 Ricoh Super 8 800z Handle Assembly Replacement: step 3, image 2 of 3 Ricoh Super 8 800z Handle Assembly Replacement: step 3, image 3 of 3
    • Remove the round metal plate.
    • Then, shift the handle so you have clearance to pass one of the legs of the button through the opening.
    Ask FixBot
  4. Ricoh Super 8 800z Handle Assembly Replacement: step 4, image 1 of 3 Ricoh Super 8 800z Handle Assembly Replacement: step 4, image 2 of 3 Ricoh Super 8 800z Handle Assembly Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Pull the button out at an angle.
    • Remove the spring beneath it with a pair of tweezers.
    Ask FixBot
  5. Ricoh Super 8 800z Handle Assembly Replacement: step 5, image 1 of 3 Ricoh Super 8 800z Handle Assembly Replacement: step 5, image 2 of 3 Ricoh Super 8 800z Handle Assembly Replacement: step 5, image 3 of 3
    • Flip the camera to the other side and remove the screws from the other round metal plate with a Phillips #000 screwdriver.
    • When replacing this plate, make sure the cutout in the plate surrounds the wiring in the handle. You may break the wiring if the plates are not seated well or if placed incorrectly.
    Ask FixBot
  6. Ricoh Super 8 800z Handle Assembly Replacement: step 6, image 1 of 3 Ricoh Super 8 800z Handle Assembly Replacement: step 6, image 2 of 3 Ricoh Super 8 800z Handle Assembly Replacement: step 6, image 3 of 3
    • Pull the handle slowly away from the camera and shift the handle to allow access to the wire connections.
    • Desolder these wires carefully and you can now remove the handle.
    • For a informative guide on how to Solder/Desolder check out this guide.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 37
All Time: 571
