Rexing V1P Plus Rear Camera Replacement
    1. Rexing V1P Plus Rear Camera Replacement, Rear Camera: step 1, image 1 of 3 Rexing V1P Plus Rear Camera Replacement, Rear Camera: step 1, image 2 of 3 Rexing V1P Plus Rear Camera Replacement, Rear Camera: step 1, image 3 of 3
      • Begin by orienting the rear camera lens facing up.
      • Twist the adhesive mount surface parallel to the camera lens.
      • Pull the mounting ring axially away from the camera case.
      Ask FixBot
    2. Rexing V1P Plus Rear Camera Replacement: step 2, image 1 of 3 Rexing V1P Plus Rear Camera Replacement: step 2, image 2 of 3 Rexing V1P Plus Rear Camera Replacement: step 2, image 3 of 3
      • Locate the small indentation on the camera case previously covered by the mounting ring.
      • Insert a spudger in the case seam and twist it to lever open the camera case.
      • Use the spudger to pry the case the rest of the way open.
      • Remove the top casing from the rear camera.
      Ask FixBot
    3. Rexing V1P Plus Rear Camera Replacement: step 3, image 1 of 2 Rexing V1P Plus Rear Camera Replacement: step 3, image 2 of 2
      • Remove the camera and camera motherboard from the casing.
      • Flip the camera board over revealing the two 3.5 mm screws on the back holding the rear camera to the board.
      Ask FixBot
    4. Rexing V1P Plus Rear Camera Replacement: step 4, image 1 of 3 Rexing V1P Plus Rear Camera Replacement: step 4, image 2 of 3 Rexing V1P Plus Rear Camera Replacement: step 4, image 3 of 3
      • Remove the two 3.5 mm screws securing the camera to the motherboard using the Phillips #00 screwdriver.
      Ask FixBot
    5. Rexing V1P Plus Rear Camera Replacement: step 5, image 1 of 1
      • With the screws removed, the rear camera can be separated from the motherboard.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 23
All Time: 664
