Rexing V1P Plus Motherboard Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
11
Past 30 Days:
52
All Time:
635
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
If your Rexing V1P Plus (also known as the Rexing V1P-4k) is not powering on, not displaying anything on the screen, or not recording audio, the device's motherboard may be damaged or faulty. This guide will walk you through how to replace the device's motherboard.
This replacement requires the removal of the device's battery. The battery on the Rexing V1P Plus does not hold a charge for long without being connected to a power source. To ensure the battery is safe to remove, leave the device unplugged for a short period to drain the battery of any charge it may have.
This replacement requires the use of a soldering iron. If you have no prior experience using a soldering iron, it is recommended to do some additional research to gain familiarity with using this tool.
Tools
    1. Rexing V1P Plus Motherboard Replacement, Front Camera: step 1, image 1 of 3 Rexing V1P Plus Motherboard Replacement, Front Camera: step 1, image 2 of 3 Rexing V1P Plus Motherboard Replacement, Front Camera: step 1, image 3 of 3
      • Begin by orienting the device with the LCD screen facing down.
      • Remove the four 6 mm screws, located on the backside of the device, using the Phillips #00 screwdriver.
      Ask FixBot
    2. Rexing V1P Plus Motherboard Replacement: step 2, image 1 of 3 Rexing V1P Plus Motherboard Replacement: step 2, image 2 of 3 Rexing V1P Plus Motherboard Replacement: step 2, image 3 of 3
      • Remove the back cover of the device and place it to the side.
      • Rotate the device 180 degrees to where the camera is facing you.
      Ask FixBot
    3. Rexing V1P Plus Motherboard Replacement: step 3, image 1 of 3 Rexing V1P Plus Motherboard Replacement: step 3, image 2 of 3 Rexing V1P Plus Motherboard Replacement: step 3, image 3 of 3
      • Remove the two 5 mm screws next to the lens using the Phillips #00 screwdriver.
      Ask FixBot
    4. Rexing V1P Plus Motherboard Replacement: step 4, image 1 of 3 Rexing V1P Plus Motherboard Replacement: step 4, image 2 of 3 Rexing V1P Plus Motherboard Replacement: step 4, image 3 of 3
      • Remove the two camera angle adjusters from the side of the device and carefully pull out the lens.
      Ask FixBot
    5. Rexing V1P Plus Motherboard Replacement: step 5, image 1 of 3 Rexing V1P Plus Motherboard Replacement: step 5, image 2 of 3 Rexing V1P Plus Motherboard Replacement: step 5, image 3 of 3
      • Remove the two 5mm screws securing the camera support bracket using the Phillips #00 screwdriver.
      Ask FixBot
    6. Rexing V1P Plus Motherboard Replacement: step 6, image 1 of 3 Rexing V1P Plus Motherboard Replacement: step 6, image 2 of 3 Rexing V1P Plus Motherboard Replacement: step 6, image 3 of 3
      • Carefully remove the plastic frame piece from its previously secured position on the motherboard.
      • It will rest loosely around the white camera ribbon.
      • Rotate the device 180 degrees to where the camera is facing away from you.
      Ask FixBot
    7. Rexing V1P Plus Motherboard Replacement: step 7, image 1 of 3 Rexing V1P Plus Motherboard Replacement: step 7, image 2 of 3 Rexing V1P Plus Motherboard Replacement: step 7, image 3 of 3
      • Carefully peel back the adhesive material covering the ribbon cable connection.
      Ask FixBot
    8. Rexing V1P Plus Motherboard Replacement: step 8, image 1 of 3 Rexing V1P Plus Motherboard Replacement: step 8, image 2 of 3 Rexing V1P Plus Motherboard Replacement: step 8, image 3 of 3
      • Using the Flathead 1.5mm screwdriver, or another pry tool, gently flip up the black ZIF connector locking flap to free the ribbon cable.
      • Once the connector is open, slide the ribbon cable out to remove it.
      Ask FixBot
    1. Rexing V1P Plus Motherboard Replacement, Motherboard: step 9, image 1 of 3 Rexing V1P Plus Motherboard Replacement, Motherboard: step 9, image 2 of 3 Rexing V1P Plus Motherboard Replacement, Motherboard: step 9, image 3 of 3
      • Using a soldering iron, disconnect the four wires connected to the motherboard.
      Ask FixBot
    2. Rexing V1P Plus Motherboard Replacement: step 10, image 1 of 3 Rexing V1P Plus Motherboard Replacement: step 10, image 2 of 3 Rexing V1P Plus Motherboard Replacement: step 10, image 3 of 3
      • Using the Phillips #00 screwdriver, remove the three 3.5 mm screws securing the motherboard to the case.
      Ask FixBot
    3. Rexing V1P Plus Motherboard Replacement: step 11, image 1 of 3 Rexing V1P Plus Motherboard Replacement: step 11, image 2 of 3 Rexing V1P Plus Motherboard Replacement: step 11, image 3 of 3
      • Pull the black antenna wire with the gold cap straight up to disconnect it from the motherboard.
      • Using your fingers, spread the case apart to provide space for the motherboard to be removed.
      • This must be done to free the connected ports from their mounting locations in the case.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 52
All Time: 635
