Up to 20% off select tools
Rexing V1P Plus Front Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
67
All Time:
559
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
If the video from your Rexing V1P Plus front camera is not recording or displaying on the screen, your device's front camera could be damaged or faulty. This guide will show you how to remove and replace the front camera.
    1. Rexing V1P Plus Front Camera Replacement, Front Camera: step 1, image 1 of 3 Rexing V1P Plus Front Camera Replacement, Front Camera: step 1, image 2 of 3 Rexing V1P Plus Front Camera Replacement, Front Camera: step 1, image 3 of 3
      • Begin by orienting the device with the LCD screen facing down.
      • Remove the four 6 mm screws, located on the backside of the device, using the Phillips #00 screwdriver.
      Ask FixBot
    2. Rexing V1P Plus Front Camera Replacement: step 2, image 1 of 3 Rexing V1P Plus Front Camera Replacement: step 2, image 2 of 3 Rexing V1P Plus Front Camera Replacement: step 2, image 3 of 3
      • Remove the back cover of the device and place it to the side.
      • Rotate the device 180 degrees to where the camera is facing you.
      Ask FixBot
    3. Rexing V1P Plus Front Camera Replacement: step 3, image 1 of 3 Rexing V1P Plus Front Camera Replacement: step 3, image 2 of 3 Rexing V1P Plus Front Camera Replacement: step 3, image 3 of 3
      • Remove the two 5 mm screws next to the lens using the Phillips #00 screwdriver.
      Ask FixBot
    4. Rexing V1P Plus Front Camera Replacement: step 4, image 1 of 3 Rexing V1P Plus Front Camera Replacement: step 4, image 2 of 3 Rexing V1P Plus Front Camera Replacement: step 4, image 3 of 3
      • Remove the two camera angle adjusters from the side of the device and carefully pull out the lens.
      Ask FixBot
    5. Rexing V1P Plus Front Camera Replacement: step 5, image 1 of 3 Rexing V1P Plus Front Camera Replacement: step 5, image 2 of 3 Rexing V1P Plus Front Camera Replacement: step 5, image 3 of 3
      • Remove the two 5mm screws securing the camera support bracket using the Phillips #00 screwdriver.
      Ask FixBot
    6. Rexing V1P Plus Front Camera Replacement: step 6, image 1 of 3 Rexing V1P Plus Front Camera Replacement: step 6, image 2 of 3 Rexing V1P Plus Front Camera Replacement: step 6, image 3 of 3
      • Carefully remove the plastic frame piece from its previously secured position on the motherboard.
      • It will rest loosely around the white camera ribbon.
      • Rotate the device 180 degrees to where the camera is facing away from you.
      Ask FixBot
    7. Rexing V1P Plus Front Camera Replacement: step 7, image 1 of 3 Rexing V1P Plus Front Camera Replacement: step 7, image 2 of 3 Rexing V1P Plus Front Camera Replacement: step 7, image 3 of 3
      • Carefully peel back the adhesive material covering the ribbon cable connection.
      Ask FixBot
    8. Rexing V1P Plus Front Camera Replacement: step 8, image 1 of 3 Rexing V1P Plus Front Camera Replacement: step 8, image 2 of 3 Rexing V1P Plus Front Camera Replacement: step 8, image 3 of 3
      • Using the Flathead 1.5mm screwdriver, or another pry tool, gently flip up the black ZIF connector locking flap to free the ribbon cable.
      • Once the connector is open, slide the ribbon cable out to remove it.
      Ask FixBot
Author
with
Ryan Horne
270 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 67
All Time: 559
