Rewriting corrupted firmware on Digitech JamMan Solo
  1. Rewriting corrupted firmware on Digitech JamMan Solo, Check for firmware updates: step 1, image 1 of 1
    • Before starting, plug your pedal to a computer using an USB mini B cable.
    • If your device is detected (for instance in Peripheral Manager for Windows users, with "lsusb" for Linux users)
    • Install the JamManager software from here
    • Try updating the firmware using JamManager
    • If your device is not detected, or if the firmware update fails, carry on with this tutorial
    • The following procedure is risky and may render your device more definitely bricked than it already was.
    Ask FixBot
  2. Rewriting corrupted firmware on Digitech JamMan Solo, Open the pedal: step 2, image 1 of 2 Rewriting corrupted firmware on Digitech JamMan Solo, Open the pedal: step 2, image 2 of 2
    • Unscrew the 4 Torx T15H holding the bottom plate
    • Free the bottom plate
    Ask FixBot
  3. Rewriting corrupted firmware on Digitech JamMan Solo, Lift the board: step 3, image 1 of 3 Rewriting corrupted firmware on Digitech JamMan Solo, Lift the board: step 3, image 2 of 3 Rewriting corrupted firmware on Digitech JamMan Solo, Lift the board: step 3, image 3 of 3
    • Unscrew the 3 jack connectors bolts
    • Lift the board from the top of the pedal
    • Unscrew the 2 Torx T15H holding the SD card
    • The board can be moved out of the pedal
    • There is no need to unmount it further to access the debug port
    • Connectors to the display and button boards and to the SD card slot are soldered, do not try to disconnect them
    Ask FixBot
  4. Rewriting corrupted firmware on Digitech JamMan Solo, Take a look at the board: step 4, image 1 of 3 Rewriting corrupted firmware on Digitech JamMan Solo, Take a look at the board: step 4, image 2 of 3 Rewriting corrupted firmware on Digitech JamMan Solo, Take a look at the board: step 4, image 3 of 3
    • Spot the debug UART port
    • Under the button when looking from the top
    • Marked as "P3" when looking from the bottom
    • UART connection requires to connect TXD, RXD and GND
    Ask FixBot
  5. Rewriting corrupted firmware on Digitech JamMan Solo, Solder debug UART cables: step 5, image 1 of 2 Rewriting corrupted firmware on Digitech JamMan Solo, Solder debug UART cables: step 5, image 2 of 2
    • Solder a 3V3 USB-UART adapter to the pins by following this pinout
    • GND connected to the adapter GND
    • TX connected to the adapter RX
    • RX connected to the adapter TX
    • You can also solder an intermediate 2.54mm DuPont-style header connector and use DuPont debug cables
    • No need to connect 3V3, RTS and CTS
    Ask FixBot
    • Connect to the USB-UART adapter using an appropriate software
    • PuTTy on Windows machines
    • Screen or Minicom on Linux machines
    • The serial parameters are: 115200, 2N1, no flow control
    • Once everything is connected, you can plug the 9V power supply to the pedal
    • It should display startup messages
    • Afterwards, it should give you a prompt with the possibility to interact with it
    • Try typing "ls"
    Ask FixBot
    • If possible, ask a friend to do the same with a working pedal
    • On the working pedal, with the USB-UART probe and with an SD Card inserted, type:
    • etfsctl -d /dev/etfs2 -r /mnt/sdfs/etfs2.structured.bin
    • cp -r /mnt/nandfs/* /mnt/sdfs/nandfs_copy
    • Otherwise, recover the files from the Internet
    • My copy of a working JamManSolo firmware
    • Copy them from your computer to the SD card
    Ask FixBot
    • Make sure you have the exact same model, JamMan Solo, do not use for the JamMan Solo HD or any other product!
    • Insert the SD card with the working files in the device and run:
    • etfsctl -d /dev/etfs2 -S -e -w /mnt/sdfs/etfs2.structured.bin -c
    • Once it is done, power cycle the device and checks if it works
    • If it is still missing files, run:
    • cp -r /mnt/sdfs/nandfs_copy/* /mnt/nandfs
    • Power cycle and verifies the device is working
    Ask FixBot
To reassemble your device, unplug it, unsolder the usb-serial adapter, and follow these instructions in reverse order.
Eve Redero
3,354 Reputation
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 24
All Time: 219
