Revlon 473 Thermal Cutout Replacement
  1. Revlon 473 Thermal Cutout Replacement, Shell: step 1, image 1 of 1
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
    Ask FixBot
  2. Revlon 473 Thermal Cutout Replacement: step 2, image 1 of 1
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
    Ask FixBot
  3. Revlon 473 Thermal Cutout Replacement: step 3, image 1 of 3 Revlon 473 Thermal Cutout Replacement: step 3, image 2 of 3 Revlon 473 Thermal Cutout Replacement: step 3, image 3 of 3
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
    Ask FixBot
  4. Revlon 473 Thermal Cutout Replacement, Thermal Cutout: step 4, image 1 of 1
    • Locate the thermal cutout under the coils of the heating element.
    Ask FixBot
  5. Revlon 473 Thermal Cutout Replacement: step 5, image 1 of 1
    • Test the thermal cutout for continuity using the multimeter.
    • Make sure the multimeter is set to 200 ACV and bring the probes toward the thermal cutout.
    • If the numbers on the multimeter continue to change, the circuit is closed and properly functioning.
    • If the multimeter reads a consistent number, the circuit is opened and the thermal cutout needs to be replaced.
    Ask FixBot
  6. Revlon 473 Thermal Cutout Replacement: step 6, image 1 of 1
    • To replace the thermal cutout, use the spudgers to extract the object.
    • To remove, wedge it back and forth until it comes free.
    • You do not need to take out the gold piece, only the thermal cutout.
    Ask FixBot
  7. Revlon 473 Thermal Cutout Replacement: step 7, image 1 of 1
    • Replace the old thermal cutout with a new thermal cutout by snapping it into place.
    Ask FixBot
Jessica Leyva
143 Reputation
5 Guides authored
Cal Poly, Team 1-5, Propen Fall 2012 Member of Cal Poly, Team 1-5, Propen Fall 2012
CPSU-PROPEN-F12S1G5
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 34
All Time: 2,329
