Up to 20% off select tools
Revlon 473 Heating Element Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
97
All Time:
2,718
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓
The heating element in the Revlon 473 is a coiled nichrome wire around insulated board. This repair would resolve hot air expulsion from the appliance. CAUTION: risk of potential electric shock due to live wires and damaged insulation. Be aware of sharp edges in the nichrome wire and board. Be sure to isolate your power source.
    1. Revlon 473 Heating Element Replacement, Shell: step 1, image 1 of 1
      • Before disassembly, make sure that the device is unplugged.
      • Remove the two 17.83 mm black screws located on the handle.
      Ask FixBot
    2. Revlon 473 Heating Element Replacement: step 2, image 1 of 1
      • Separate the shell from the main component.
      • Check to ensure each piece is free from debris.
      Ask FixBot
    3. Revlon 473 Heating Element Replacement: step 3, image 1 of 3 Revlon 473 Heating Element Replacement: step 3, image 2 of 3 Revlon 473 Heating Element Replacement: step 3, image 3 of 3
      • Remove the casing from the heating element.
      • For reassembly, reattach the silver casing before the black cover.
      Ask FixBot
    1. Revlon 473 Heating Element Replacement, Heating Element: step 4, image 1 of 1
      • The heating element is the group of tightly coiled bronze wires behind the vent hose as well as the silver coils.
      • Make sure that there are no breaks or debris obstructing the wires of the heating element.
      Ask FixBot
    2. Revlon 473 Heating Element Replacement: step 5, image 1 of 1
      • To test the heating element, use a digital multimeter.
      • Set the multimeter to 200 under ACV (alternating current voltage).
      • Bring the ends of the multimeter toward the two lead wires.
      • If the circuit between the wires is closed, the numbers on the multimeter should keep changing.
      • If the numbers are not changing, replace the heating element.
      • If the circuit is closed, check the thermal cutout.
      Ask FixBot
Author
with
Jessica Leyva
143 Reputation
5 Guides authored
Cal Poly, Team 1-5, Propen Fall 2012 Member of Cal Poly, Team 1-5, Propen Fall 2012
CPSU-PROPEN-F12S1G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 97
All Time: 2,718
