Retroid Pocket Flip Speakers Replacement
    1. Retroid Pocket Flip Speakers Replacement, Back Plate Assembly: step 1, image 1 of 2 Retroid Pocket Flip Speakers Replacement, Back Plate Assembly: step 1, image 2 of 2
      • Remove the four 5.9 mm screws from the backplate of the device with a 1.3mm hex screwdriver.
      • Use a plastic opening pick to carefully separate the back cover from the device.
      Ask FixBot
    2. Retroid Pocket Flip Speakers Replacement: step 2, image 1 of 2 Retroid Pocket Flip Speakers Replacement: step 2, image 2 of 2
      • Use a plastic spudger to carefully lift and disconnect the battery connector.
      • Use tweezers to disconnect the connector from its socket.
      Ask FixBot
    1. Retroid Pocket Flip Speakers Replacement, Speakers: step 3, image 1 of 1
      • Use tweezers or a spudger to disconnect the two speaker cables at the bottom of the board and remove them.
      Ask FixBot
Kristen Gismondi
109,025 Reputation
271 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 57
All Time: 151
