Up to 20% off select tools
Retroid Pocket Flip Screen Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
45
Past 30 Days:
259
All Time:
1,255
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the screen in a Retroid Pocket Flip handheld gaming console. The screen displays all visual output during gameplay and system navigation. If the screen is cracked, shows dead pixels, flickers, or no longer turns on, it may need to be replaced.
This repair is difficult and requires full disassembly of the device, including motherboard removal.
Before beginning, power off the device completely and remove the microSD card. Follow Electrostatic Discharge when working inside the device to prevent damage to sensitive electronic components.
The screen is fragile. Avoid bending, twisting, or applying pressure during removal to prevent damage.
    1. Retroid Pocket Flip Screen Replacement, Back Plate Assembly: step 1, image 1 of 2 Retroid Pocket Flip Screen Replacement, Back Plate Assembly: step 1, image 2 of 2
      • Remove the four 5.9 mm screws from the backplate of the device with a 1.3mm hex screwdriver.
      • Use a plastic opening pick to carefully separate the back cover from the device.
      Ask FixBot
    2. Retroid Pocket Flip Screen Replacement: step 2, image 1 of 2 Retroid Pocket Flip Screen Replacement: step 2, image 2 of 2
      • Use a plastic spudger to carefully lift and disconnect the battery connector.
      • Use tweezers to disconnect the connector from its socket.
      Ask FixBot
    1. Retroid Pocket Flip Screen Replacement, Joystick: step 3, image 1 of 2 Retroid Pocket Flip Screen Replacement, Joystick: step 3, image 2 of 2
      • Remove the two 3.2 mm screws securing the top of the shield with a JIS #000 screwdriver.
      • Remove the five 3.2mm screws securing the plastic insulating shield to the motherboard.
      • Use tweezers to remove the "R" sticker to reveal the last screw.
      Ask FixBot
    2. Retroid Pocket Flip Screen Replacement: step 4, image 1 of 3 Retroid Pocket Flip Screen Replacement: step 4, image 2 of 3 Retroid Pocket Flip Screen Replacement: step 4, image 3 of 3
      • Carefully lift and unstick the fan module using a plastic spudger, then remove it.
      • Remove the sticky ribbon connectors on each side of the plate with a plastic spudger.
      • Use a plastic spudger to carefully separate the shield from the board.
      • Do not pull abruptly: the shield is partially bonded to the CPU with thermal paste. You can use a hair dryer on low heat to soften the paste slightly before lifting the shield.
      Ask FixBot
    3. Retroid Pocket Flip Screen Replacement: step 5, image 1 of 3 Retroid Pocket Flip Screen Replacement: step 5, image 2 of 3 Retroid Pocket Flip Screen Replacement: step 5, image 3 of 3
      • Use tweezers to unclip and remove the two ribbon cables on each joystick module.
      • Use a plastic spudger to lift and remove the joystick modules; they are secured with double sided tape.
      Ask FixBot
    1. Retroid Pocket Flip Screen Replacement, Motherboard: step 6, image 1 of 3 Retroid Pocket Flip Screen Replacement, Motherboard: step 6, image 2 of 3 Retroid Pocket Flip Screen Replacement, Motherboard: step 6, image 3 of 3
      • Use a plastic spudger to disconnect the sliding connector by pushing on the tab to slide it out of its socket.
      • Use tweezers to disconnect the ribbon cables from the board.
      • Disconnect the coaxial connector on the left of the motherboard by positioning tweezers under the metal neck of the connector to lift it straight up.
      • Always lift the coaxial connector straight up. Do not pry at an angle, as this can detach the socket from the motherboard.
      Ask FixBot
    2. Retroid Pocket Flip Screen Replacement: step 7, image 1 of 2 Retroid Pocket Flip Screen Replacement: step 7, image 2 of 2
      • Remove the six 5.8 mm screws from the motherboard using a JIS #00 screwdriver.
      • Carefully lift the motherboard out of the device.
      Ask FixBot
    1. Retroid Pocket Flip Screen Replacement, Screen: step 8, image 1 of 3 Retroid Pocket Flip Screen Replacement, Screen: step 8, image 2 of 3 Retroid Pocket Flip Screen Replacement, Screen: step 8, image 3 of 3
      • Use a plastic opening pick to carefully separate the screen from its back cover.
      • Use a plastic spudger to disconnect the first ribbon cable.
      • Use tweezers to disconnect the second ribbon cable.
      Ask FixBot
    2. Retroid Pocket Flip Screen Replacement: step 9, image 1 of 2 Retroid Pocket Flip Screen Replacement: step 9, image 2 of 2
      • Use a JIS #000 screwdriver to remove the two 3.2mm screws securing the hinge.
      • Carefully pivot the screen display assembly to separate it from the bottom half.
      • As you pull the two halves apart, carefully guide the ribbon cable through the hinge opening.
      • Do not pull on or bend the cables.
      Ask FixBot
    3. Retroid Pocket Flip Screen Replacement: step 10, image 1 of 1
      • Once the cable is free, fully separate the screen assembly from the lower half of the device.
      Ask FixBot
Author
with
Melissa Boussa
331 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 45
Past 30 Days: 259
All Time: 1,255
