Retroid Pocket Flip L1/R1 Shoulder Buttons Replacement
    1. Retroid Pocket Flip L1/R1 Shoulder Buttons Replacement, Back Plate Assembly: step 1, image 1 of 2 Retroid Pocket Flip L1/R1 Shoulder Buttons Replacement, Back Plate Assembly: step 1, image 2 of 2
      • Remove the four 5.9 mm screws from the backplate of the device with a 1.3mm hex screwdriver.
      • Use a plastic opening pick to carefully separate the back cover from the device.
      Ask FixBot
    2. Retroid Pocket Flip L1/R1 Shoulder Buttons Replacement: step 2, image 1 of 2 Retroid Pocket Flip L1/R1 Shoulder Buttons Replacement: step 2, image 2 of 2
      • Use a plastic spudger to carefully lift and disconnect the battery connector.
      • Use tweezers to disconnect the connector from its socket.
      Ask FixBot
    1. Retroid Pocket Flip L1/R1 Shoulder Buttons Replacement, L1/R1 Shoulder Buttons: step 3, image 1 of 1
      • Remove the two shoulder buttons from each side.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 63
All Time: 215
