Retroid Pocket Flip Joystick Replacement
    1. Retroid Pocket Flip Joystick Replacement, Back Plate Assembly: step 1, image 1 of 2 Retroid Pocket Flip Joystick Replacement, Back Plate Assembly: step 1, image 2 of 2
      • Remove the four 5.9 mm screws from the backplate of the device with a 1.3mm hex screwdriver.
      • Use a plastic opening pick to carefully separate the back cover from the device.
      Ask FixBot
    2. Retroid Pocket Flip Joystick Replacement: step 2, image 1 of 2 Retroid Pocket Flip Joystick Replacement: step 2, image 2 of 2
      • Use a plastic spudger to carefully lift and disconnect the battery connector.
      • Use tweezers to disconnect the connector from its socket.
      Ask FixBot
    1. Retroid Pocket Flip Joystick Replacement, Speakers: step 3, image 1 of 1
      • Use tweezers or a spudger to disconnect the two speaker cables at the bottom of the board and remove them.
      Ask FixBot
    1. Retroid Pocket Flip Joystick Replacement, Joystick: step 4, image 1 of 2 Retroid Pocket Flip Joystick Replacement, Joystick: step 4, image 2 of 2
      • Remove the two 3.2 mm screws securing the top of the shield with a JIS #000 screwdriver.
      • Remove the five 3.2mm screws securing the plastic insulating shield to the motherboard.
      • Use tweezers to remove the "R" sticker to reveal the last screw.
      Ask FixBot
    2. Retroid Pocket Flip Joystick Replacement: step 5, image 1 of 3 Retroid Pocket Flip Joystick Replacement: step 5, image 2 of 3 Retroid Pocket Flip Joystick Replacement: step 5, image 3 of 3
      • Carefully lift and unstick the fan module using a plastic spudger, then remove it.
      • Remove the sticky ribbon connectors on each side of the plate with a plastic spudger.
      • Use a plastic spudger to carefully separate the shield from the board.
      • Do not pull abruptly: the shield is partially bonded to the CPU with thermal paste. You can use a hair dryer on low heat to soften the paste slightly before lifting the shield.
      Ask FixBot
    3. Retroid Pocket Flip Joystick Replacement: step 6, image 1 of 3 Retroid Pocket Flip Joystick Replacement: step 6, image 2 of 3 Retroid Pocket Flip Joystick Replacement: step 6, image 3 of 3
      • Use tweezers to unclip and remove the two ribbon cables on each joystick module.
      • Use a plastic spudger to lift and remove the joystick modules; they are secured with double sided tape.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 39
Past 30 Days: 210
All Time: 465
