Introduction
Use this guide to replace the directional pad (D-pad) in a Retroid Pocket Flip handheld gaming console. The D-pad is used for directional input during gameplay and menu navigation. If the D-pad becomes unresponsive, registers incorrect inputs, or feels uneven when pressed, it may need to be replaced.
This repair requires moderate technical experience because internal components must be removed to access the D-pad.
Before beginning, power off the device completely and remove the microSD card. Battery, joystick, and motherboard removal are required before accessing the D-pad. Follow Electrostatic Discharge when working inside the device to prevent damage to sensitive components.
Remove the four 5.9 mm screws from the backplate of the device with a 1.3mm hex screwdriver.
Use a plastic opening pick to carefully separate the back cover from the device.
Remove the two 3.2 mm screws securing the top of the shield with a JIS #000 screwdriver.
Remove the five 3.2mm screws securing the plastic insulating shield to the motherboard.
Use a plastic spudger to disconnect the sliding connector by pushing on the tab to slide it out of its socket.
Use tweezers to disconnect the ribbon cables from the board.
Disconnect the coaxial connector on the left of the motherboard by positioning tweezers under the metal neck of the connector to lift it straight up.
Remove the rubber piece backing the D-pad out of the device.
Lift the D-pad out of the device.
