Up to 20% off select tools
Retroid Pocket Flip Back Plate Assembly Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
99
All Time:
546
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the back plate assembly on your Retroid Pocket Flip, or as a prerequisite to access the internals.
    1. Retroid Pocket Flip Back Plate Assembly Replacement, Back Plate Assembly: step 1, image 1 of 2 Retroid Pocket Flip Back Plate Assembly Replacement, Back Plate Assembly: step 1, image 2 of 2
      • Remove the four 5.9 mm screws from the backplate of the device with a 1.3mm hex screwdriver.
      • Use a plastic opening pick to carefully separate the back cover from the device.
      Ask FixBot
    2. Retroid Pocket Flip Back Plate Assembly Replacement: step 2, image 1 of 2 Retroid Pocket Flip Back Plate Assembly Replacement: step 2, image 2 of 2
      • Use a plastic spudger to carefully lift and disconnect the battery connector.
      • Use tweezers to disconnect the connector from its socket.
      Ask FixBot
Author
with
Kristen Gismondi
110,418 Reputation
271 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 99
All Time: 546
