Retroid Pocket 3 Motherboard Replacement
    1. Retroid Pocket 3 Motherboard Replacement, Battery: step 1, image 1 of 1
      • Unplug any cables connected to the Retroid Pocket 3+.
      • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
      Ask FixBot
    2. Retroid Pocket 3 Motherboard Replacement: step 2, image 1 of 3 Retroid Pocket 3 Motherboard Replacement: step 2, image 2 of 3 Retroid Pocket 3 Motherboard Replacement: step 2, image 3 of 3
      • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
      • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
      Ask FixBot
    3. Retroid Pocket 3 Motherboard Replacement: step 3, image 1 of 2 Retroid Pocket 3 Motherboard Replacement: step 3, image 2 of 2
      • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
      • Lift off the metal plate.
      Ask FixBot
    4. Retroid Pocket 3 Motherboard Replacement: step 4, image 1 of 3 Retroid Pocket 3 Motherboard Replacement: step 4, image 2 of 3 Retroid Pocket 3 Motherboard Replacement: step 4, image 3 of 3
      • Use a plastic opening tool or spudger to unclip the battery connector.
      • Carefully lift the battery from the case.
      • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
      • Lift and remove the battery.
      Ask FixBot
    1. Retroid Pocket 3 Motherboard Replacement, Motherboard: step 5, image 1 of 1
      • Remove the three 4.5 mm screws with a Phillips #00 screwdriver on the main board.
      Ask FixBot
    2. Retroid Pocket 3 Motherboard Replacement: step 6, image 1 of 1
      • Using a spudger, put the tip under the aerial connecter and rotate upwards to unclip the plug.
      Ask FixBot
    3. Retroid Pocket 3 Motherboard Replacement: step 7, image 1 of 1
      • Unclip and remove the one ribbon cable on the left.
      Ask FixBot
    4. Retroid Pocket 3 Motherboard Replacement: step 8, image 1 of 1
      • Use a spudger to unclip and remove the two ribbon cables on the right side.
      Ask FixBot
    5. Retroid Pocket 3 Motherboard Replacement: step 9, image 1 of 2 Retroid Pocket 3 Motherboard Replacement: step 9, image 2 of 2
      • Use a spudger to disconnect the two speaker cables on the bottom of the board.
      Ask FixBot
    6. Retroid Pocket 3 Motherboard Replacement: step 10, image 1 of 3 Retroid Pocket 3 Motherboard Replacement: step 10, image 2 of 3 Retroid Pocket 3 Motherboard Replacement: step 10, image 3 of 3
      • Start lifting the board to give you access to the vibration motor on the metal case.
      • Use a spudger to carefully pry the motor free; it is bound with double-sided tape.
      • Carefully lift the board out of the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 75
All Time: 1,574
