Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓If your screen on your Retroid Pocket 3 is damaged showing: dead pixels, touch malfunction, flickering screen, black spots, lines, discoloration, a totally black screen or cracks on the screen, your LCD screen needs replacement. Follow this guide that will take you step by step on how to replace your LCD screen on your Retroid Pocket 3. This process will take approximately 40 minutes, and the tools required for this project are listed in the guide.
Parts
https://www.goretroid.com/collections/diy/products/retroid-pocket-3-handheld-console-plastic-shell For sale from another site
The screen is pre-installed in the front case.
Tools
Spudger4.9
Unplug any cables connected to the Retroid Pocket 3+.
Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
Remove the three 4.5 mm screws with a Phillips #00 screwdriver on the main board.
Undo the ribbon cable clips using the Spudger tool.
Unclip the cable on the left side of the board.
Carefully lift the ribbon cable to the right to remove it from the clip.
Using the spudger, put the tip under the top round clip at the top.
Carefully start lifting the clip to slide it off the plastic pin on the case, tilting the trigger button as you lift it to remove.
Using the Spudger tool, remove the two speakers at the bottom of the device by gently prying them out.
1 Guide Comment
Hello. Can you tell where I can find a new replacement screen?
