Up to 20% off select tools
Retroid Pocket 3 Button Pad Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
124
All Time:
1,657
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
If the device buttons on your Retroid Pocket 3 are not responding to touch, follow this guide to remove and replace the faulty button pad and install a new one. This process will take approximately 25-30 minutes to complete, and the tools needed for replacement are listed in this guide.
    1. Retroid Pocket 3 Button Pad Replacement, Battery: step 1, image 1 of 1
      • Unplug any cables connected to the Retroid Pocket 3+.
      • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
      Ask FixBot
    2. Retroid Pocket 3 Button Pad Replacement: step 2, image 1 of 3 Retroid Pocket 3 Button Pad Replacement: step 2, image 2 of 3 Retroid Pocket 3 Button Pad Replacement: step 2, image 3 of 3
      • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
      • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
      Ask FixBot
    3. Retroid Pocket 3 Button Pad Replacement: step 3, image 1 of 2 Retroid Pocket 3 Button Pad Replacement: step 3, image 2 of 2
      • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
      • Lift off the metal plate.
      Ask FixBot
    4. Retroid Pocket 3 Button Pad Replacement: step 4, image 1 of 3 Retroid Pocket 3 Button Pad Replacement: step 4, image 2 of 3 Retroid Pocket 3 Button Pad Replacement: step 4, image 3 of 3
      • Use a plastic opening tool or spudger to unclip the battery connector.
      • Carefully lift the battery from the case.
      • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
      • Lift and remove the battery.
      Ask FixBot
    1. Retroid Pocket 3 Button Pad Replacement, Button Pad: step 5, image 1 of 3 Retroid Pocket 3 Button Pad Replacement, Button Pad: step 5, image 2 of 3 Retroid Pocket 3 Button Pad Replacement, Button Pad: step 5, image 3 of 3
      • Undo the ribbon cable clips using the Spudger tool.
      • Unclip the cable on the left side of the board.
      • Carefully lift the ribbon cable to the right to remove it from the clip.
      Ask FixBot
    2. Retroid Pocket 3 Button Pad Replacement: step 6, image 1 of 2 Retroid Pocket 3 Button Pad Replacement: step 6, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the three 5.9 mm screws from the controller board.
      • Carefully lift the board out of the device.
      Ask FixBot
    3. Retroid Pocket 3 Button Pad Replacement: step 7, image 1 of 2 Retroid Pocket 3 Button Pad Replacement: step 7, image 2 of 2
      • Using the Spudger tool, put the tip under the edge of the rubber button pad to start lifting it.
      • Button pad will loosen and lift straight out of the casing.
      Ask FixBot
    4. Retroid Pocket 3 Button Pad Replacement: step 8, image 1 of 1
      • Move to the right side of the device.
      • Using a spudger, undo the ribbon cable clip connected to the main PCB along with the joystick ribbon cable.
      Ask FixBot
    5. Retroid Pocket 3 Button Pad Replacement: step 9, image 1 of 3 Retroid Pocket 3 Button Pad Replacement: step 9, image 2 of 3 Retroid Pocket 3 Button Pad Replacement: step 9, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the two 5.9 mm screws.
      Ask FixBot
    6. Retroid Pocket 3 Button Pad Replacement: step 10, image 1 of 3 Retroid Pocket 3 Button Pad Replacement: step 10, image 2 of 3 Retroid Pocket 3 Button Pad Replacement: step 10, image 3 of 3
      • Carefully pry up the silicone button pad with a Spudger tool.
      Ask FixBot
Author
with
Cassidy Anderson
271 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 124
All Time: 1,657
