Up to 20% off select tools
Retroid Pocket 3 Battery Replacement
Views: 5.7K
View statistics:
Past 24 Hours:
8
Past 7 Days:
44
Past 30 Days:
225
All Time:
5,748
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If the device is not powering on or holding a charge, this guide will assist you in removing and replacing the battery in the Retroid Pocket 3 safely. This process will take approximately 15-20 minutes, and the tools needed for the project are listed in this guide.
For your safety, turn off the device and ensure the battery is fully discharged before starting this process. If your battery looks puffy or swollen, take extra precautions when removing the battery. Remember to follow general electrostatic discharge (ESD) safety procedures when removing the battery.
Do not reuse the old battery after it has been removed, as it can cause a safety hazard.
    1. Retroid Pocket 3 Battery Replacement, Battery: step 1, image 1 of 1
      • Unplug any cables connected to the Retroid Pocket 3+.
      • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
      Ask FixBot
    2. Retroid Pocket 3 Battery Replacement: step 2, image 1 of 3 Retroid Pocket 3 Battery Replacement: step 2, image 2 of 3 Retroid Pocket 3 Battery Replacement: step 2, image 3 of 3
      • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
      • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
      Ask FixBot
    3. Retroid Pocket 3 Battery Replacement: step 3, image 1 of 2 Retroid Pocket 3 Battery Replacement: step 3, image 2 of 2
      • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
      • Lift off the metal plate.
      Ask FixBot
    4. Retroid Pocket 3 Battery Replacement: step 4, image 1 of 3 Retroid Pocket 3 Battery Replacement: step 4, image 2 of 3 Retroid Pocket 3 Battery Replacement: step 4, image 3 of 3
      • Use a plastic opening tool or spudger to unclip the battery connector.
      • Carefully lift the battery from the case.
      • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
      • Lift and remove the battery.
      Ask FixBot
Author
with
Cassidy Anderson
271 Reputation
2 Guides authored
1 Guide Comment
Hi, the battery of the Retroid Pocket 3 and 3Plus is customized for the manufacturing company, so it is not possible to find it in online stores and Retroid does not sell it as a spare part. Can you suggest a battery that has similar characteristics such as size, voltage and capacity? The battery is a 755565 3.8V and 4000mAh (for the Retroid 3 and 4500mAh for the 3Plus), can you suggest a 3.7V battery but with similar dimensions? Better a little smaller, otherwise it does not close inside the case. Thanks
Gianluca - Reply Share
Past 24 Hours: 8
Past 7 Days: 44
Past 30 Days: 225
All Time: 5,748
