Retro-Bit Retro Duo Controller Button and Pad Replacement.
  1. Retro-Bit Retro Duo Controller Button and Pad Replacement., Buttons and Pads in Controller(s): step 1, image 1 of 3 Retro-Bit Retro Duo Controller Button and Pad Replacement., Buttons and Pads in Controller(s): step 1, image 2 of 3 Retro-Bit Retro Duo Controller Button and Pad Replacement., Buttons and Pads in Controller(s): step 1, image 3 of 3
    • With the controller on its face, remove the five 6 mm Phillips #1 screws.
    • After screw removal, carefully lift the controller casing.
  2. Retro-Bit Retro Duo Controller Button and Pad Replacement.: step 2, image 1 of 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: step 2, image 2 of 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: step 2, image 3 of 3
    • Pinch the top and bottom of the shoulder pads, then lift out.
    • There are small elastic pads below each shoulder pad. Replace these if they are not functioning correctly.
  3. Retro-Bit Retro Duo Controller Button and Pad Replacement.: step 3, image 1 of 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: step 3, image 2 of 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: step 3, image 3 of 3
    • Carefully lift the circuit board from the controller case.
  4. Retro-Bit Retro Duo Controller Button and Pad Replacement.: step 4, image 1 of 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: step 4, image 2 of 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: step 4, image 3 of 3
    • To replace the action button pad, lift this part out.
    • Lift the Select and Start button pad.
    • If replacing the D-Pad, lift this pad.
    • Pinch and lift the shoulder button pads.
  5. Retro-Bit Retro Duo Controller Button and Pad Replacement.: step 5, image 1 of 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: step 5, image 2 of 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: step 5, image 3 of 3
    • Support the controller face and push buttons toward the inner case.
    • Use care. The buttons have a tiny tab to keep them in place.
    • Support the controller face and push the D-Pad toward the inner case.
Evelyn
228 Reputation
2 Guides authored
USF Tampa, Team S4-G4, Eyestone Fall 2017 Member of USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 29
All Time: 1,451
