Up to 20% off select tools
Restroom Sink Replacement
Views: 1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
118
All Time:
1,016
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
Replacing a sink is important to do when it is old or doesn't appeal to the eye. Some people don't change it because it could be an expensive job when you involve a plumber. But it turns out to be a simple job that anyone can do. It will not only save time but will also save money. Due to covid, some homeowners might not want to bring in strangers to their homes. This avoids the fear and discomfort of being placed in said situation. All you need is a plier and gloves. If you are changing the hardware you might need to purchase a plumber's cement.
Once the job is complete, check for leaks under the sink to avoid damage to the sink cabinet.
    1. Restroom Sink Replacement, Restroom Sink: step 1, image 1 of 3 Restroom Sink Replacement, Restroom Sink: step 1, image 2 of 3 Restroom Sink Replacement, Restroom Sink: step 1, image 3 of 3
      • Turn off the water source beneath the sink.
      • If the sink is a bit old or rusted, make sure to wipe it with wipes and paper towels.
      • Wear Gloves for better grip of knobs and to prevent spills over your hand or arm.
      Ask FixBot
    2. Restroom Sink Replacement: step 2, image 1 of 3 Restroom Sink Replacement: step 2, image 2 of 3 Restroom Sink Replacement: step 2, image 3 of 3
      • Turn on the knobs on the sink to confirm the water is off and release the remaining water.
      • Always have a container ready when checking for remaining water to catch in.
      • Once you are finished reassuring, you can move onto step 3.
      Ask FixBot
    3. Restroom Sink Replacement: step 3, image 1 of 3 Restroom Sink Replacement: step 3, image 2 of 3 Restroom Sink Replacement: step 3, image 3 of 3
      • Gently loosen the elbow that connects the sink to the pipe leading to the wall with pliers.
      • Use a container to catch any water in the elbow.
      • Don't use too much strength to avoid damage to the wall pipping as you loosen the elbow.
      Ask FixBot
    4. Restroom Sink Replacement: step 4, image 1 of 3 Restroom Sink Replacement: step 4, image 2 of 3 Restroom Sink Replacement: step 4, image 3 of 3
      • With a sharp blade, cut along the old silicon to detach the sink from the cabinet.
      • Use blase with caution to avoid injury to self or damage to the sink.
      • Then detach the hoses from below the sink.
      • Beware, water might be in the hoses as you detach them.
      Ask FixBot
    5. Restroom Sink Replacement: step 5, image 1 of 3 Restroom Sink Replacement: step 5, image 2 of 3 Restroom Sink Replacement: step 5, image 3 of 3
      • When you are done with steps 1 through 4, remove the old sink and replace it with the new one.
      • If your new sink is a newer model, make sure it has the same length and width with a measuring tape.
      • Beware to avoid damage to the sink or cabinet, if it is placed by force.
      Ask FixBot
    6. Restroom Sink Replacement: step 6, image 1 of 3 Restroom Sink Replacement: step 6, image 2 of 3 Restroom Sink Replacement: step 6, image 3 of 3
      • Reconnect the hoses and turn on the water with the knobs under the sink, to make sure it runs smoothly.
      • Apply silicon to seal areas around sink and let it dry.
      • Wait for the silicon to dry before using it.
      Ask FixBot
To conclude, replacing a sink seems like a tedious job. But, any beginner can do it without a plumber's assistance. Therefore, saving lots of money on labor.
Author
with
Robertcastillo
142 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 118
All Time: 1,016
