Restroom Exhaust Fan Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
6
Past 7 Days:
37
Past 30 Days:
180
All Time:
2,245
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This is a quick and simple guide on how to remove your old restroom ceiling fan. The replacement part for this guide can be found here.
    1. Restroom Exhaust Fan Replacement, Vent Fan Motor & Blower Wheel: step 1, image 1 of 2 Restroom Exhaust Fan Replacement, Vent Fan Motor & Blower Wheel: step 1, image 2 of 2
      • Turn off the breaker to the bathroom light in your home's circuit panel.
      • If the fuse is not labelled, you can turn the bathroom fan on and turn off fuses until the bathroom fan is turned off. Be sure to turn off the bathroom fan before starting the fix even though the fuse may be turned off.
      Ask FixBot
    2. Restroom Exhaust Fan Replacement: step 2, image 1 of 2 Restroom Exhaust Fan Replacement: step 2, image 2 of 2
      • Carefully remove the grill cover on the unit by grasping the outer edges and pulling downward, toward the floor.
      Ask FixBot
    3. Restroom Exhaust Fan Replacement: step 3, image 1 of 2 Restroom Exhaust Fan Replacement: step 3, image 2 of 2
      • Pinch the mounting wires toward each other and pull downward. Do this on both sides.
      • Dust accumulation should be expected. You may want to wear a mask and eye protection to avoid falling dust.
      Ask FixBot
    4. Restroom Exhaust Fan Replacement: step 4, image 1 of 2 Restroom Exhaust Fan Replacement: step 4, image 2 of 2
      • Unplug the unit. Using a circuit tester, confirm that there is no power running through the fan's circuit.
      Ask FixBot
    5. Restroom Exhaust Fan Replacement: step 5, image 1 of 1
      • Remove the entire fan housing assembly from the ceiling.
      • Be careful that the outer edge of the assembly does not make contact with the drywall as not to damage it.
      • Do not touch the ceiling with hands to avoid leaving fingerprints.
      Ask FixBot
3 other people completed this guide.
Kolton
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 37
Past 30 Days: 180
All Time: 2,245
