Resetting the System Management Controller (SMC) on your Mac
Views: 5.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
27
Past 30 Days:
179
All Time:
5,667
Comments: 2
2 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Introduction
Go to step 1 ↓
The following symptoms may mean an SMC reset is needed:
  • Your computer's fans are running at high speed, even if the computer is not under heavy load and is properly ventilated.
  • Keyboard backlight works incorrectly.
  • Status light, if present, is malfunctioning.
  • Battery LEDs, if present, work incorrectly (for Mac laptops with a non-removable battery).
  • The display backlight does not react correctly to changes in brightness.
  • Your Mac does not respond when you press the power button.
* Your Mac laptop does not respond properly when you close or open the lid.
* Your Mac goes to sleep or shuts down unexpectedly.
  • The battery does not charge properly.
  • MagSafe Power Adapter LED does not indicate correct activity.
  • Your Mac is abnormally slow, although its processor is not heavily used.
  • A computer that supports the target display mode does not switch between modes as expected, or switches between modes unexpectedly.
  • Mac Pro (Late 2013) I/O ports are not illuminated when moving the computer.
      • Try each of the following steps in the order listed before resetting the SMC. Check after each troubleshooting step if the issue still persists.
      • If your Mac isn't responding, force shut it down by pressing and holding the power button for 10 seconds. Any unsaved data in open applications will however be lost.
      • Press Command+Option+Esc to force quit any unresponsive app.
      • Put your Mac in sleep mode by choosing Sleep from the Apple menu. Wake the computer after it went to sleep mode.
      • Restart your Mac by choosing Restart from the Apple menu.
      • Shut down your Mac by choosing Shut Down from the Apple menu, then turn it back on.
      Ask FixBot
      • If you're using a Mac laptop that's having power or battery issues, follow these steps:
      • Unplug the Mac's power adapter and power outlet for a few seconds, then plug them back in.
      • Shut down your Mac.
      • Remove and reinsert the battery (if removable).
      • Restart your Mac.
      Ask FixBot
Finish Line
5 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
2 Guide Comments
Thank you a lot
Ola Agboola - Reply Share
Salut bon j’ai un souci avec mon ordinateur mac book pro mi 2012
Si je rallume mon ordinateur à 1 ou 2 minutes il planque et j’entends un bruit à l’intérieur
J’aimerais savoir d’où vient le problème
Mor Gueye - Reply Share
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 179
All Time: 5,667
