Up to 20% off select tools
Resetting the Clock
Views: 2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
5
Past 30 Days:
43
All Time:
1,965
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Resetting the Clock
Introduction
Go to step 1 ↓
The following step-by-step guide will show you how to successfully reset the clock on a Nextplay Fashion iPod Docking Clock Radio, also known as NP109CR.
    1. Resetting the Clock, Resetting the Clock: step 1, image 1 of 1
      • Locate the buttons named "SET", "SKIP", "VOLUME -", and "VOLUME +", which are situated on the top portion of the Nextplay NP109CR.
      Ask FixBot
    2. Resetting the Clock: step 2, image 1 of 2 Resetting the Clock: step 2, image 2 of 2
      • Press the "SET" button, the first button from the left in the row located behind the pink snooze bar, three (3) times until the clock display is flashing.
      Ask FixBot
    3. Resetting the Clock: step 3, image 1 of 1
      • Press the "SKIP" button with the two triangles next to it pointing to the right to advance the hour.
      Ask FixBot
    4. Resetting the Clock: step 4, image 1 of 1
      • Press the "SKIP" button with the two triangles pointing to the left to retreat the hour.
      Ask FixBot
    5. Resetting the Clock: step 5, image 1 of 1
      • Press the "VOLUME +" button to advance the minutes forward.
      Ask FixBot
    6. Resetting the Clock: step 6, image 1 of 1
      • Press the "VOLUME -" button to decrease the minutes.
      Ask FixBot
Once the desired time has been set, the display will continue flashing for about five (5) seconds. When the clock has stopped flashing the clock has been reset successfully. Setting the clock can be very useful when traveling or when living in an area with frequent power outages.
Author
with
Jacob Aube
1 Reputation
1 Guide authored
Cal Poly, Team 7-50, Forte Fall 2012 Member of Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 43
All Time: 1,965
