Up to 20% off select tools
Resetting Windows 10
Views: 6.4K
View statistics:
Past 24 Hours:
6
Past 7 Days:
57
Past 30 Days:
247
All Time:
6,379
Comments: 2
2 guide comments.
Go to guide comments
Completed: 21
21 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 5 hours
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Using Settings, we're going to initiate a Windows reset.
This is the catchall, the nuclear option, this method will fix most, if not every problem with windows 10.
There are many reasons why you may want to reset windows
  1. If your PC is running slow and can't figure out why.
  2. Your concerned that you have a virus and your anti-virus isn't picking anything up.
  3. Vital parts of windows have failed due to a botched update/upgrade.
  4. The stars have aligned and you had a vision telling you to do it.
What ever the reason, the process is now simpler than ever with windows 10, follow the steps below to begin!
    1. Resetting Windows 10, Open settings: step 1, image 1 of 2 Resetting Windows 10, Open settings: step 1, image 2 of 2
      • Press Windows + I to open your settings window.
      • Then click "Update & security"
      Ask FixBot
    2. Resetting Windows 10, Recovery: step 2, image 1 of 1
      • From the settings window click "Recovery"
      Ask FixBot
    3. Resetting Windows 10, Reset: step 3, image 1 of 1
      • From the recovery menu click "Get started" under "Reset this PC"
      Ask FixBot
    4. Resetting Windows 10, Keep or Remove your files: step 4, image 1 of 1
      • You are then asked to choose one of two options. Pick one that would best suit your needs.
      • Keep my Files: This will keep any files you have stored in the windows Documents, Pictures and Videos folders etc. This will result in a fresh install of windows but keep all your files.
      • Remove everything: This will completely refresh the windows OS, free from any files or apps that where on before, any files stored on other drives or partitions will remain. Make sure you back up any data you want to keep before choosing this option.
      Ask FixBot
    5. Resetting Windows 10, A few more clicks: step 5, image 1 of 3 Resetting Windows 10, A few more clicks: step 5, image 2 of 3 Resetting Windows 10, A few more clicks: step 5, image 3 of 3
      • After a short wait, windows will let you know what apps will be uninstalled. Click "Next"
      • After reading a quick overview of what is about to happen. Click "Reset"
      Ask FixBot
    6. Resetting Windows 10, Lots of loading: step 6, image 1 of 3 Resetting Windows 10, Lots of loading: step 6, image 2 of 3 Resetting Windows 10, Lots of loading: step 6, image 3 of 3
      • The rest is automatic and will take some time. Make yourself a cup of tea and relax.
      Ask FixBot
    7. Resetting Windows 10, Finishing touches: step 7, image 1 of 3 Resetting Windows 10, Finishing touches: step 7, image 2 of 3 Resetting Windows 10, Finishing touches: step 7, image 3 of 3
      • Once the reset is finished just log in as normal.
      • Windows will make a few final changes, and your done!
      • On your desktop will be a html file that will contain all the apps that were removed.
      Ask FixBot
21 other people completed this guide.
Author
with
Conor Bailey
8,280 Reputation
2 Guides authored
Tech Haus Member of Tech Haus
Business
1 Member
24 Guides authored
2 Guide Comments
Really nice information to the techies and readers... who want to do the job yourself.. I m sure anyone can reset the laptop , if he she follows the instructions mentioned here.
ncrsystemsolution - Reply Share
what if you forgot your password and you won’t open it. you want to reset your laptop what should i do?
John Paul - Reply Share
Past 24 Hours: 6
Past 7 Days: 57
Past 30 Days: 247
All Time: 6,379
