ResMed VPAP Auto 25 Circuit Board Replacement
  1. ResMed VPAP Auto 25 Circuit Board Replacement, Circuit Board: step 1, image 1 of 3 ResMed VPAP Auto 25 Circuit Board Replacement, Circuit Board: step 1, image 2 of 3 ResMed VPAP Auto 25 Circuit Board Replacement, Circuit Board: step 1, image 3 of 3
    • Remove the four 26.7 mm T3 Torx screws from the bottom side of the ResMed VPAP Auto 25.
    Ask FixBot
  2. ResMed VPAP Auto 25 Circuit Board Replacement: step 2, image 1 of 3 ResMed VPAP Auto 25 Circuit Board Replacement: step 2, image 2 of 3 ResMed VPAP Auto 25 Circuit Board Replacement: step 2, image 3 of 3
    • Flip the device over.
    • Pry the outermost plastic cover off with the metal spudger until the cover is loose and able to be removed.
    Ask FixBot
  3. ResMed VPAP Auto 25 Circuit Board Replacement: step 3, image 1 of 2 ResMed VPAP Auto 25 Circuit Board Replacement: step 3, image 2 of 2
    • Pull off the front cover to reveal the internal components.
    Ask FixBot
  4. ResMed VPAP Auto 25 Circuit Board Replacement: step 4, image 1 of 3 ResMed VPAP Auto 25 Circuit Board Replacement: step 4, image 2 of 3 ResMed VPAP Auto 25 Circuit Board Replacement: step 4, image 3 of 3
    • Loosen the motherboard from the rubber dowels holding it in place and unplug the screen components.
    Ask FixBot
  5. ResMed VPAP Auto 25 Circuit Board Replacement: step 5, image 1 of 3 ResMed VPAP Auto 25 Circuit Board Replacement: step 5, image 2 of 3 ResMed VPAP Auto 25 Circuit Board Replacement: step 5, image 3 of 3
    • Remove the three 26.7 mm T3 Torx screws from the now visible rubber fan motor cover.
    • Lift off the rubber fan motor cover, revealing the fan motor.
    Ask FixBot
  6. ResMed VPAP Auto 25 Circuit Board Replacement: step 6, image 1 of 3 ResMed VPAP Auto 25 Circuit Board Replacement: step 6, image 2 of 3 ResMed VPAP Auto 25 Circuit Board Replacement: step 6, image 3 of 3
    • Remove the fan motor unit from its housing.
    • Remove the three 26.7 mm screws securing the motor housing to the bottom piece with a T3 Torx screwdriver.
    Ask FixBot
  7. ResMed VPAP Auto 25 Circuit Board Replacement: step 7, image 1 of 3 ResMed VPAP Auto 25 Circuit Board Replacement: step 7, image 2 of 3 ResMed VPAP Auto 25 Circuit Board Replacement: step 7, image 3 of 3
    • Pull out the fan motor housing from the bottom cover, revealing a foam insulation pad and the circuit board.
    • Slide the circuit board out of its plastic grooves in the bottom cover to retrieve the desired component.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 426
