ResMed S9 VPAP Auto Knob Replacement
  1. ResMed S9 VPAP Auto Knob Replacement, Control Knob: step 1, image 1 of 2 ResMed S9 VPAP Auto Knob Replacement, Control Knob: step 1, image 2 of 2
    • Flip the device upside down.
    • Use a T3 Torx screwdriver to remove the screw in the corner.
    • Each screw in this guide is a 1.2mm Torx T3.
    Ask FixBot
  2. ResMed S9 VPAP Auto Knob Replacement: step 2, image 1 of 2 ResMed S9 VPAP Auto Knob Replacement: step 2, image 2 of 2
    • Use a spudger to pry off the back panel.
    Ask FixBot
  3. ResMed S9 VPAP Auto Knob Replacement: step 3, image 1 of 2 ResMed S9 VPAP Auto Knob Replacement: step 3, image 2 of 2
    • Use the spudger to pry off the front panel.
    • If you are having difficulty, press the two hooks to open that side of the device.
    • Remove the front panel to expose the internal components.
    Ask FixBot
  4. ResMed S9 VPAP Auto Knob Replacement: step 4, image 1 of 3 ResMed S9 VPAP Auto Knob Replacement: step 4, image 2 of 3 ResMed S9 VPAP Auto Knob Replacement: step 4, image 3 of 3
    • Remove the two screws on the circuit board with a T3 Torx screwdriver.
    Ask FixBot
  5. ResMed S9 VPAP Auto Knob Replacement: step 5, image 1 of 2 ResMed S9 VPAP Auto Knob Replacement: step 5, image 2 of 2
    • Plug in and heat up the soldering iron.
    Ask FixBot
  6. ResMed S9 VPAP Auto Knob Replacement: step 6, image 1 of 3 ResMed S9 VPAP Auto Knob Replacement: step 6, image 2 of 3 ResMed S9 VPAP Auto Knob Replacement: step 6, image 3 of 3
    • Locate the knob pins.
    • Desolder the solder pins on each side of the knob.
    • For more details on soldering best practices, check out our How To Solder and Desolder Connections guide.
    • Be careful not to make contact with any of the other parts of the motherboard.
    • Remove the knob and replace it.
    Ask FixBot
3 other people completed this guide.
4 Guide Comments
Do you have a source for the auto knob or a part number?
scott jensen - Reply Share
Do you have a source for this knob/switch or a part number?
You need a new rotary encoder, however the very popular and cheap EC11 does not work properly, you need a ddm 427 encoder, which is not very easy to find.
NG G. - Reply Share
I found the right encoder from digikey. It has the wrong type of knob stem, but it works. It is the DDM 427.
Jim Burianek - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 59
All Time: 1,257
