This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Replacing the why! W840xx SSD
    1. Replacing the why! W840xx SSD, Battery: step 1, image 1 of 3 Replacing the why! W840xx SSD, Battery: step 1, image 2 of 3 Replacing the why! W840xx SSD, Battery: step 1, image 3 of 3
      • Unlock the battery latch on the right.
      • Unlock the battery lock on the left.
      • Remove the battery pack from its slot.
      Ask FixBot
    1. Replacing the why! W840xx SSD, Lower Case: step 2, image 1 of 3 Replacing the why! W840xx SSD, Lower Case: step 2, image 2 of 3 Replacing the why! W840xx SSD, Lower Case: step 2, image 3 of 3
      • Using the Philips # 0 screwdriver, unscrew the 2 screws of the top cover
      • Check the marks indicating the direction in which the cover must be removed.
      • Remove the bottom cover by removing it in the direction of the markers.
      Ask FixBot
    2. Replacing the why! W840xx SSD: step 3, image 1 of 1
      • Then appear the other components of the Laptop.
      Ask FixBot
    1. Replacing the why! W840xx SSD, SSD disk: step 4, image 1 of 3 Replacing the why! W840xx SSD, SSD disk: step 4, image 2 of 3 Replacing the why! W840xx SSD, SSD disk: step 4, image 3 of 3
      • This is the SSD drive
      • Unscrew the fixing screw of the SSD using the Philips # 0 screwdriver.
      • Remove the SSD.
      Ask FixBot
    2. Replacing the why! W840xx SSD: step 5, image 1 of 1
      • Here is the SSD drive out of its slot.
      Ask FixBot
For reassembly, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 119
All Time: 2,258
