Replacing the thermal paste on a graphics card
    1. Replacing the thermal paste on a graphics card, Exterior view: step 1, image 1 of 1
      • In this accessible tutorial, I will show you how to replace the thermal paste on a graphics card. The method applies to all cards.
      Ask FixBot
    2. Replacing the thermal paste on a graphics card, Remove the screws securing the heatsink-fan assembly: step 2, image 1 of 2 Replacing the thermal paste on a graphics card, Remove the screws securing the heatsink-fan assembly: step 2, image 2 of 2
      • You will have to remove the Phillips screws to detach the heat sink and the fan from the card. Some cards may be equipped with a shroud, but there isn't one on this one.
      • The screws to be removed (Red Circles)
      • I also advise to unscrew the screws in an "X" pattern (a turn or two at a time for each) so that the force exerted by the screws is very uniform and does not damage the card.
      Ask FixBot
    3. Replacing the thermal paste on a graphics card, Disassembly of the heatsink/fan assembly: step 3, image 1 of 3 Replacing the thermal paste on a graphics card, Disassembly of the heatsink/fan assembly: step 3, image 2 of 3 Replacing the thermal paste on a graphics card, Disassembly of the heatsink/fan assembly: step 3, image 3 of 3
      • It is important to remove the fan leads with care not to damage them. Disconnecting them can be tricky.
      • Graphics processor (GPU) in my case, it's a Radeon HD 7790
      • Video memory chips (VRAM) in GDDR5, on this card we have a total of 1gb of memory spread over 4 256 MB chips.
      • 6-pin 12v connector for power supply.
      • The voltage regulator modules (VRM) permit the delivery and regulate the power supplied to the GPU, VRAM etc ...
      • Connectors for video and audio such as HDMI, DVI and Display Port.
      • VRAM dedicated thermal pads.
      • Heat sink to dissipate the heat generated by the GPU VRM's and VRAM.
      Ask FixBot
    4. Replacing the thermal paste on a graphics card, Replacing the thermal paste: step 4, image 1 of 3 Replacing the thermal paste on a graphics card, Replacing the thermal paste: step 4, image 2 of 3 Replacing the thermal paste on a graphics card, Replacing the thermal paste: step 4, image 3 of 3
      • Remove the old thermal paste with a cotton swab and isopropyl alcohol. Then, apply a new dose of thermal paste (it's inexpensive).
      • After replacing the heat sink on the GPU, the thermal paste will spread.
      • Be careful not to use too much or too little paste. To be sure of the amount, you can spread it out with a card.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
4 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Shibe
193 Reputation
1 Guide authored
2 Guide Comments
Do i have to replace the thermal pads too?
Mateusz - Reply Share
I'm sorry, i was a bit busy, but if the thermal pads are still intact and making contact with the chip and heatsink, you can keep them.
Shibe - Reply Share
Past 24 Hours: 19
Past 7 Days: 111
Past 30 Days: 639
All Time: 9,042
