Up to 20% off select tools
Replacing the friction pads
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
72
All Time:
942
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Thrustmaster sells spare part through their online Eshop.
You can also contact Thrsutmaster technical support to get spare part if not available in your region.
    1. Replacing the friction pads, Open the Throttle: step 1, image 1 of 3 Replacing the friction pads, Open the Throttle: step 1, image 2 of 3 Replacing the friction pads, Open the Throttle: step 1, image 3 of 3
      • Unscrew these 5 screws
      • Remove the metal plate
      Ask FixBot
    2. Replacing the friction pads, Remove the PCB: step 2, image 1 of 3 Replacing the friction pads, Remove the PCB: step 2, image 2 of 3 Replacing the friction pads, Remove the PCB: step 2, image 3 of 3
      • Unscrew the 4 screws, disconnect all the connectors and take off the PCB
      • Remove the 4 screws, disconnect all wires and remove the PCB.
      Ask FixBot
    3. Replacing the friction pads, Remove the screws: step 3, image 1 of 3 Replacing the friction pads, Remove the screws: step 3, image 2 of 3 Replacing the friction pads, Remove the screws: step 3, image 3 of 3
      • Remove 8 screws highlighted on the picture.
      Ask FixBot
    4. Replacing the friction pads, Remove the friction pads: step 4, image 1 of 3 Replacing the friction pads, Remove the friction pads: step 4, image 2 of 3 Replacing the friction pads, Remove the friction pads: step 4, image 3 of 3
      • Push the lever arms to gain access to the friction pads.
      • You can now remove the Friction pads
      Ask FixBot
      • You can now change your friction pads
      Ask FixBot
Reassemble the product by following this procedure in reverse order.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Attached Documents
Author
with
Avrila
1,377 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 72
All Time: 942
